Home > My New Defender (L663) > Picked my D200 110SE today |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1337 |
Latest upgrade is the fitting of an alcantara steering wheel and the flappy paddles from the V8, they aren't activated yet so can't wait until I get them done. I also fitted a dark grey steering wheel trim to replace the white one
Click image to enlarge I also fitted an alcantara gear lever trim piece to match the steering wheel Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
26th Feb 2023 3:26pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 849 |
wheel looks good.
gear lever trim ....... looks like a 'hoodie' |
26th Feb 2023 4:30pm |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1061 |
Sorry, but it just looks wrong, particularly the gear knob.
26th Feb 2023 5:25pm |
and that's fine, you're not the one driving it Cheers Ian
26th Feb 2023 6:13pm |
Just thought I would update my thread with a couple of things added. I now have working flappy paddles courtesy of David and the team at https://huntersprestige.com/ The main reason that I wanted the flappy paddles was for off road so you can either go up or down the box without taking your hands off the wheel but I must admit I've used them on the tarmac quite a bit also
Following the lead from Marco (https://www.defender2.net/forum/topic88338.html) I also fitted the clearsight mirror, I was unable to get this when I bought the car so it has been a welcome addition. Click image to enlarge Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
1st Aug 2023 5:34pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
Nice work.
1st Aug 2023 6:57pm |
Latest update to the car, I've fitted a lightbar and an 8 way switch, I've only got the lightbar wired up at the moment but have plans for more items to fit to use some of the other switches. The lightbar is the Osram one that Powerful are selling with their brackets to mount it to the Land Rover Rack. The switch is a copy of the Auxbeam one which I got from Aliexpress for a lot less than the Auxbeam one. I followed the installation instructions from Manou which can be found in this thread https://www.defender2.net/forum/topic80449-30.html
I also bought 2 sheets of Aluminium from Ebay to manufacture the switch bracket and control unit bracket for under the bonnet as per Manou's diagrams. I had considered buying the switch pro mounts from the States but they are very expensive and the shipping was really steep so the two sheets of aluminium only cost £9-10 from Ebay, they might not be as pretty but I can live with that for the saving. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
9th Oct 2023 9:36pm |
Latest edition is a roof tent, just in time for some summer camping/green lanning trips. Supplied and fitted by Brendan at 4x4 Overlander.
23rd Apr 2024 11:58am |
