Home > Faults & Fixes (L663) > Water noise |
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 22 |
I had to remove a rubber grommet from the underside to drain it
27th May 2021 11:02pm |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 |
You need to find out where its getting in - because I am sure long term that wont be good...
back to the dealer.. |
28th May 2021 6:07am |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 |
There’s a known SSM for water ingress mine is getting something done next time it goes in but they didn’t say where it was.
28th May 2021 11:53am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
Water ingress is in the DNA of all Defenders.....
28th May 2021 3:44pm |
Mines going in on the 16th for various faults/fixes will update on the water ingress then.
28th May 2021 4:44pm |
Will book it in and also see if they can sort out the SIM card not always working for online services 🤞
28th May 2021 9:35pm |
Archon Member Since: 26 Feb 2024 Location: Wales Posts: 2 |
Resurrecting an old post... was this ever sorted? After hearing sloshing i took the grommet out and gallons poured out
It's going in tomorrow by chance anyway and still by a whisker in warranty Any help gratefully received First post so please be gentle thanks |
26th Feb 2024 11:13am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4507 |
Might be beneficial to leave the drain grommet out until the issue is sorted. 1982 88" 2.25 diesel
26th Feb 2024 5:19pm |
Yes, thanks, done that. Problem is grommet isnt at lowest point so there’s still a reservoir behind
26th Feb 2024 5:26pm |
Probably seems like heresy saying this, but would it be feasible to drill a hole at the lowest point to stop water building up? Just make the diameter the same as the existing whole and you can plug it with a grommet when the issue is solved. If you do drill a new hole do not for get to put some paint on the new edges to stop it rusting. 1982 88" 2.25 diesel
26th Feb 2024 5:35pm |
