Home > 130 > Shock absorbers |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7712 |
Old man emu Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
18th Jan 2021 9:32am |
You could do a lot worse than standard Land Rover ones. Britpart substitutes are rubbish in my experience. If you want softer suspension though, you'll also need to look at springs as the standard on a 130 will be heavy duty. Darren
18th Jan 2021 9:33am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3333 |
I'm running standard springs (with rear helpers) and shocks on mine. Does the trick.
18th Jan 2021 10:28am |
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 |
As others have said, standard Land Rover ones work well.
If you find the ride too harsh and you don't carry heavy loads you could remove the inner helper springs. My 130 is a station wagon and I have kept the helper springs and don't find the ride harsh. |
18th Jan 2021 12:28pm |
johnnyha Member Since: 08 May 2019 Location: London Posts: 40 |
snap |
14th Dec 2021 1:05pm |
Danny Fireblade Member Since: 16 Mar 2018 Location: Hampshire Posts: 301 |
OME if you want a good ride.
14th Dec 2021 3:29pm |
