Home > Technical > AMR2983 Fuse Box
CB Chris
AMR2983 Fuse Box
Hi,
Long shot, but does anyone have any decent photos of the inside/outside of a AMR2983 fuse box as used in the Wolf?
I am looking at building my own from scratch as trying to find an original is as good as impossible, and would like some original photos to work from.
Alternatively, is there a plug in alternative available?
Cheers in advance to anyone that can help! Very Happy
Post #868252 19th Nov 2020 10:22am
pepethekingprawn
United Kingdom 1989 Defender 90 V8 Petrol ST Auto Chawton White
Here you go. From a new spare item I have in my garage.
Post #870776 1st Dec 2020 7:01pm
Oldowner
I have quite a few of them, I broke up lots of 300tdi defenders some years ago.
Post #871054 2nd Dec 2020 11:52pm
Karlslandyz
United Kingdom 1990 Defender 110 300 Tdi SW Java Black
Hi oldowner do you still have any 300 tdi under bonnet maxi fuse boxes about thanks
Post #889050 4th Mar 2021 6:23pm
gbpmi
United Kingdom 1997 Defender 110 300 Tdi ST Nato Green
Good morning,
Any chance you could sell one to me please?
I'm partway through a 100% rebuild and the cap is missing and rear clips have broken away at some time before I had the vehicle.
TIA.
Post #1031330 12th Apr 2024 9:43am
Oldowner
I binned them all ages ago, no-one wanted them when I offered them three years ago
Post #1031382 12th Apr 2024 10:47pm
gbpmi
OK, no worries and thank you for the reply.
Post #1031383 12th Apr 2024 11:00pm
NickMc
Have you tried the likes of PAblanchards? They’ve a lot of ex mod, don’t reply to emails though you’ll have to be old fashioned on the phone.
Post #1031469 13th Apr 2024 11:46pm
gbpmi
Thank you, I have, yes. None at the moment unfortunately, but thank you again for the reply.
Post #1031479 14th Apr 2024 8:12am
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
Mine is broken also.
It seems like just the sort of thing that someone would 3D print.
Its on my to-do list but I've been hoping someone else would get there first!
Post #1031489 14th Apr 2024 10:29am
gbpmi
Please let me know if you do and IF you do, please improve the design and material flexibility.
Built to crack.
Post #1031503 14th Apr 2024 11:31am
NickMc
Other place to try is autosparks that remanufacture looms
Post #1031576 14th Apr 2024 10:53pm
gbpmi
I tried Autosparks 2 days ago and they don't have them, but they do offer an alternative solution, although I have not pursued that yet.
Here's what Paul at Autosparks said yesterday:
"Our solution on the harnesses we build is to use 3 x 655-601, clipped together makes a 3-way fuse box in its own right. When wired up replaces the original Land Rover assembly".
Maybe someone with the requisite auto-electrical knowledge could explain further?
Post #1032038 18th Apr 2024 5:52pm
julian
They are saying to use three of these -
https://www.autosparks.co.uk/in-line-maxi-...-6mm-cable
...but that is no better than the broken unit, as its not like your part isnt electrically working, it just does not mount correctly.
And three of the above would also not mount to the original bracket.
So it would work if you had nothing at all, but is no better than a broken OEM one.
Post #1032043 18th Apr 2024 6:04pm
PaulMc
As the 300Tdi engine compartment fuse box distributes power from a single feed, I would suggest that this is a more suitable alternative -
https://www.polevolt.co.uk/acatalog/4-way-...HA500.html
 Paul.
Post #1032047 18th Apr 2024 6:17pm
