Home > Td5 > Immobilizer?? |
Rutlandtravels Member Since: 13 Apr 2024 Location: Napoli Posts: 9 |
Andy, is that the brown wire that attaches to the starter motor?
13th Apr 2024 1:30pm |
andylee Member Since: 29 Jun 2016 Location: South East Posts: 89 |
Should run from negative battery through the side of the seat box and onto the chassis, from there it branches to gearbox. These connections get corroded and brittle and then don't provide enough of an earth to power the starter. I replaced the jumper from chassis to gearbox to fix my issue
good luck. "Just saw your post about a 300tdi this picture is a Td5 so may be different" A Click image to enlarge |
13th Apr 2024 4:42pm |
Thank you, Sir. Good picture. I inspected that ground and while it is old, the clamp connecting the wire to the chassis is intact. Not assessing the need to conduct the Britannica sandblast and re-solder.
I seem to be having immobilizer issues as well. Original fobs are functional, but won't re-mobilize the truck; she's a '98 CSW, no power locks. Alarm has never sounded, but I get single blink (engine side small orange light) feedback upon unlock, no feedback upon lock other than a double click from RHD driver side. EKA isn't working either. I've started to take the dash apart today to get a look at the green alarm box back there, and I've just discovered evidence of rodent meanderings on the plethora of wires back there. Nothing appears to be chewed clean thru, just several plastic sheaths a bit mangled. On to figuring out how to test the ignition switch and alarm fuses/relays. Had knee surgery Tuesday. The mental anguish of both these issues at the same time is wearing me thin! |
13th Apr 2024 5:16pm |
keep at it and good luck, perseverance will prevail, you might find more advice on the 300tdi thread,
13th Apr 2024 5:56pm |
