Home > 130 > Passing cabin connection to cargo bay 130
Page 3 of 3 <123
mopadzi
Czech Republic
Yes, you're right. The wheels are used during construction. Once completed, the car will be equipped with other wheels. The tyres will remain these Cooper ST Max.
Post #888617 2nd Mar 2021 1:44pm
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Ok, that's alright then. All the best with the build! Defender 130 HCPU Td5 MY2000
Post #888714 2nd Mar 2021 9:31pm
mopadzi
Czech Republic
Hello, everyone, our construction continues. We're in a phase right before the auto assembly.
Post #904891 25th May 2021 10:21am
mopadzi
Czech Republic
Interframes ready. They are strong enough with high torsional stiffness to avoid cracking the claws of the housing superstructure while driving in the field and crunching the base chassis of the car.
Post #904892 25th May 2021 10:29am
mopadzi
Czech Republic
We used the original Def130 rear window frame to connect the cabin to the living space. The two frames will be connected in axis against each other by a flexible blade. This will provide permanent emergency access between the two parts of the car.
Post #904894 25th May 2021 10:38am
Smyles_
Denmark 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
This is so very very cool!
Appreciate you keeping us up to date. Some nice custom fabrication work there Thumbs Up Stuart
Cummins 130 Build Thread
Instagram
04 110 Double Cab - Black (gone)
58 130 Double Cab HCPU - Cairns Blue
Post #904902 25th May 2021 11:16am
L110CDL
+1 Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #905017 25th May 2021 9:19pm
mopadzi
Czech Republic
Hello, everyone, we finally have a residential extension on the car. However, there is still a lot of work to be done with the integration of the superstructure with the car and the interior of the residential superstructure itself.
Post #907205 10th Jun 2021 12:20pm
mopadzi
Czech Republic
Post #907206 10th Jun 2021 12:21pm
Smyles_
Wow Shocked
That looks absolutely fantastic Thumbs Up
I like how you've also managed to integrate an external roll cage in there too. Top work. Bow down Stuart
Instagram
Post #907213 10th Jun 2021 12:46pm
mopadzi
Czech Republic
Very thanks Very Happy
Post #907215 10th Jun 2021 12:51pm
mopadzi
Czech Republic
Post #907216 10th Jun 2021 12:52pm
Page 3 of 3 <123
