Home > Wheels & Tyres (L663) > Largest Offroad Tire on Stock 22" rims |
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 269 |
Just double checking if I would have any problems fitting these 285/45/R22 Nokian Rotiiva AT tyres to my on order Defender 110 with 22" style 5098 wheels? as I don't think there is much choice of AT tyres at this size
Michael https://www.mytyres.co.uk/cgi-bin/rshop.pl...p=R-420609 |
25th Mar 2021 9:20am |
DFNDR22 Member Since: 06 Aug 2022 Location: Toronto Posts: 2 |
I'm planning to get the Ridge Grapplers as well (in 285/45/22) - has anyone driven them in the winter? Wondering if they are a good improvement in freezing conditions over the all-season Continentals the P400 came with?
6th Aug 2022 8:14pm |
rutiger Member Since: 30 Dec 2020 Location: wa Posts: 32 |
i made it through 2 winters in washington with ridge grapplers. not the greatest in freezing temps or snow imo. they felt a little sketchy in snow & ice. had to drive extra carefully.
i plan to switch to falken wildpeak at3w soon. we've had them on 4 jeeps and they're much better in snow & rain. |
30th Aug 2022 7:18pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Cooper discoverer AT3 285/45 22 yes they rub the arch front and back of the front arches. I do have spacers fitted.
Click image to enlarge Click image to enlarge 130's have feeling's as well you know |
30th Aug 2022 8:18pm |
I'm looking at the same tires. I have 30m spacers fitted. What size spacers are you running? Is the rubbing only in low mode? Are you keeping this setup or is the rubbing really bad?
17th Sep 2022 11:32pm |
OldDD Member Since: 17 Jan 2016 Location: Ballaugh Posts: 53 |
Have any of you guys had any experience with Accelera MT-01?
They look like extremely good value for money but I can't find a review from a Defender owner running 22" wheels - What's the catch?? |
18th Dec 2022 3:02pm |
My spacers are 25mm, they only rub a little in low mode when turning. 130's have feeling's as well you know |
20th Dec 2022 12:35am |
D300110 Member Since: 07 Sep 2021 Location: NI Posts: 8 |
Thinking of putting a set of Cooper AT3 4S on my defender 110 HSE . Stock tyres are 275/45 R22 so was going to go with the same. Interesting to read above that the 285 version rubs on the arches. I don’t have spacers so hopefully be ok with same tyre size, though I’m told the outer wall of the tyre is much more square than the continentals they will be replacing.
I also saw one defender recently with these on which had the white outer writing. It looked immense. Does anyone have these fitted on 22s and if so would you mind sharing a couple pics? Thanks a lot! |
1st Jul 2023 6:34am |
Moo Member Since: 01 Oct 2021 Location: Bath Posts: 1061 |
I've gone smaller from 20-18 inch and have got some TuffAnts with 265/65/18 Radar Renegade R/T tyres to put on.
I've seen quite a few 20 inch AT tyres get side wall damage off-roading, so not sure I'd want to push 22 inches off-road too much. Click image to enlarge Click image to enlarge Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
1st Jul 2023 10:30am |
