Home > 130 > TD5 MT82 and puma Dash, can it get any harder? |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 |
A couple shops have figured out adapters to relocate the shifters aft enough to fit the tunnels. Some have gotten by with putting a dogleg bend in the shifter.
29th Aug 2020 1:24am |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
I have seen that done on r380, i dont think they make the same adapter for the MT82.
I feel if i line up the gearbox to the mounts and relocate the engine mounts it should all line up. I scored a GW DC propshaftt for a puma as mine will hopefully be in the same position. Can't leave well enough alone |
29th Aug 2020 5:00am |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2877 |
Would it not be more cost effective to go auto🤔
29th Aug 2020 9:12am |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3044 |
Naf, have you considered a sequential box?
https://shop.quaife.co.uk/quaife-land-rove...al-gearbox WARNING. This post may contain sarcasm. |
29th Aug 2020 4:52pm |
Very content with my 6speed MT82 currently..
I was tickled with the idea, but its just a wast for me, as i am truly happy with the mt82 and 1.1 TC ratio. Latest update. Need to find the bracket that holds the fuses and relays under the steering wheel. Mine wasn't supplied with the kit, and it doesn't look like i can source it separately... Waitin on a dhl shipment with my new cnc wiper houses and essential under dash parts before I press forward. Can't leave well enough alone |
1st Nov 2020 12:55pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 581 |
CNC viper houses? Please more info.
Rear propshaft - 30mm shorter is a lot, probably it needs to be shortened. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
3rd Nov 2020 9:01am |
CNC wiper houses
https://www.designdevelopmenteng.co.uk/sto...p118376562 Not cheap though Currently the engine was shifted rearwards 50mm, i used the front Puma double cardone Propshaft, and it fit perfectly...The rear propshaft needs to be about 1450mm fully collapsed as at rest i am 1480mm and closest the axle comes is 1460 when I lift the rear bumper to the point the axle dangles. I am not removin the springs, its too big of a job for similar results Can't leave well enough alone |
3rd Nov 2020 9:56am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7876 |
I have to admire your willingness to push the boundaries, that sounds some serious engineering!!! Can't help feeling its more the challenge your after than just working aircon? Must be easier ways than moving the engine and gearbox surely? Aircon unit on the roof?
Dan Padmore, Pace Automotive has just done the following "Puma Dash... MT82 6 speed transmission, Td5 engine with VNT" look them up on Facebook. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
3rd Nov 2020 2:22pm |
I saw that, i was 2/3 ahead of him six months ago.
Md eng helped source the mt82 conversion for me, and i loved it. Truly loved it. The puma dash has to have the gearbox moved back for the mt82 shifters have a slot they fit into. There are hacks for the puma dash, ministry of defender, pace automotive to name a few. I wanted the whole tdci bulkhead as to reduce the air leaks into the cab. I have the new 2.4 seatbox, and yes, there is a difference!!! Just bought a new blower as the one that came with the bulkhead is missin some plastic bits to hold it on. Very expensive venture when you try to do it the stock way... Can't leave well enough alone |
3rd Nov 2020 3:00pm |
All you needed was to fit this ti you’re r380
Click image to enlarge You could ask them to make one for your box cheers chris |
3rd Nov 2020 5:10pm |
Well the deed of movin is done.
I am waitin on the adapters so i may button up this project and start enjoyin this money pit before my season ends again... Can't leave well enough alone |
6th Nov 2020 5:05pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
Hi, just wondering if you made any more progress with your build?
I’m doing the same conversion with genuine Puma dash installed and deciding now if I keep the dogleg in my gearstick or look at fitting a disco box or use an adapter like in the pic above. I’ve got a custom aircon specialist looking at options next week.. |
23rd Oct 2021 10:42am |
