![]() | Home > Puma (Tdci) > Wiper System & Dealer |
On our way back home, after recent holiday in France, had reason to use Wipers for a long period of time ( typical UK summer)
![]() As any problem was under warranty decided to visit dealer - Stratstone Landrover in Cardiff - Foreman and Service Manager from Service Dept came out to vehicle - listened and looked ( I was expecting the usual " It's a Defender Sir, they all do that " ) but instead I got " I'll get the drive cable and 2 spindle boxes ordered - should be here by Tuesday and we'll give you a call to arrange a date, Sir. The Drive motor sounds fine." RESULT. ![]() ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
I am on my third set of spindle boxes etc now.
Wipers work fine when the noise starts, it is the clunking sound that gets annoying after a while. Bob |
Too True.
![]() Must be a regular problem because the Dealer agreed so readily to replace them. ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
On the spindle boxes as well, you can "push" in the tab thing and tighten them up (reduce the backlash)
this helps stop a lot of the clunking. |
