Home > Puma (Tdci) > Low range light |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5028 |
This was asked some time ago and is something i would really like to active...is it on the early workshop manual? Mike
25th Nov 2008 10:16pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7730 |
i couldnt find any ref to it in manuals etc, these or on line, did a quick search here and didnt find an answer either. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
25th Nov 2008 11:07pm |
Well i suppose logically its either got to be:
A switch on the High Low selector or a sensor that detects the transfer box setting. Mike |
25th Nov 2008 11:13pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
James/Mike if you do get it working lets us know. 2.4 90 XS
29th Nov 2008 11:17am |
I will have a look around the box area - if i do find something ill have a go, failing that i wont...james... Mike
29th Nov 2008 11:21am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
When you say early how early Mine is an early one and does not have a light. |
8th Dec 2008 6:14pm |
all the launch vehicles had them working and the first ones we had through work had them, so 1st 6mths would be my guess - whenever that was. Cheers
8th Dec 2008 9:32pm |
Verdone Member Since: 30 Apr 2008 Location: Gent Posts: 67 |
Received mine july 2007 and no low range light
8th Dec 2008 11:47pm |
More cut backs ! 2.4 90 XS
9th Dec 2008 9:52am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Mine was one of the first on the road but does not have the light?
9th Dec 2008 10:23am |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Do we need another light? The Defender has a little stick and the D3 has none. so... I reckon I know when I am in low range without a light due to only getting to 2 km/h in first gear at 4000 rpm so I don't need a low range light but the CDL light is more important because it tells me that damage might ensue regardless of being in low or high range. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
9th Dec 2008 10:31am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Try it in really, really soft sand. I went to take off in low third and got low one Oh boy can low range dig you a BIG hole Definitely don't need a light for low range. But I might need one for the gear selection 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
9th Dec 2008 10:44am |
9th Dec 2008 10:52am |
Just thinking about it............ I expect the all have them and they simply don't work
9th Dec 2008 11:26am |
