Home > Puma (Tdci) > 500 is possible |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 |
speed is the devils work Devon Rover - I think that's by all accounts excellent for a 2.2. oh. did someone mention the 'magical 500' ? .....you're mistaken. 600 is the magical number ....or perhaps I should say 617 |
3rd Aug 2017 5:16pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Amazing. Filled up my tank yesterday. Drove 537.1 km and filled up again: 68.16 l. Almost only highway cruising 100-110 km/h. Really can't understand how you guys get those mileages on a single tank! 😅
22nd Aug 2017 8:50pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
The 130 effect 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
22nd Aug 2017 9:52pm |
If I'd drive 130 km/h on the highway, then... Oh wait. I get it. The 130 effect. Think I need to chop the car in half then? 😬
22nd Aug 2017 10:20pm |
Try cruising at 50-55 mph |
22nd May 2023 7:22pm |
Do you know much money I spent on fuel waiting for your answer?!
Anyways. Recently switched to 285 tires so maybe I should try cruising at 40? |
22nd May 2023 7:58pm |
so sorry. life is less fun spending all my time working and not defendering. I hope you're having more fun. and hope you enjoy the new tyres. and 40 is a good speed. |
22nd May 2023 8:01pm |
Racedriver Member Since: 24 Jan 2019 Location: Buckinghamshire Posts: 112 |
Best I could ever get from my 2015 USW was 22 mpg, however it did have a lot of bolt on bits hence a lot of weight, it had 18" wheels with mud terrain tyres and a roof rack with LED light bar to reduce efficiency.
24th May 2023 4:33pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
Brilliant!! |
24th May 2023 6:47pm |
Jimbob292 Member Since: 06 Nov 2023 Location: Derby Posts: 13 |
That's really good, what tyres & pressures do you run, I'm lucky to reach 320 on a M11/A14 run |
3rd Apr 2024 6:48am |
Ecco Member Since: 31 Oct 2015 Location: Kuala Lumpur Posts: 279 |
..im regularly scoring 750-770Km on full tank..mind you, top speed on the highway is 85, max 95 kmh..faster than this and range i mentioned is not possible..so it seems rpm between 1600-1900 on 6th gear, gives best range that i was able to reach(770Km, and still no orangy light but needle is close to lowest line)..
3rd Apr 2024 6:57am |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 540 |
My 110 2.2 TDCi.
Typical mixed (country lanes, town, A road and DCW) is typically 28MPG. A long steady run on A roads (50 - 55 MPH) and it's in to the low 30s MPG. |
7th Apr 2024 1:40pm |
erm....its been that long I can't remember. it was either the standard conti or the standard good years - no idea on pressures but again would be close to factory recommended. sorry. I think the thing to note here is I'm driving slowly - deliberately slow to achieve best mpg's. |
13th Apr 2024 1:32pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 960 |
I’ve just been on a road trip to Cornwall in my 2.4 Puma and managed to get 375 miles from a full tank to the fuel light illumination. I thought that’s was pretty good even with some bad traffic hold ups.
I used premium diesel and always add Millers fuel enhancer. Not sure if it helps but makes me feel good about wanting to protect the fuel system and engine. Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
13th Apr 2024 1:46pm |
