Home > Other Site Sponsors > Futuranet Puma Gauges Controller |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6490 |
Just ask if you have any questions Lots of progress made in the last few months with this, including the launch of the system controller which integrates air con control, ABS/traction and more! Plus a load more supported engines - but a 200 Tdi is easy, one of the first we did https://www.fnltd.co.uk/shop/puma-system-controller-p114.html 1988 90 Td5 NAS soft top 2015 D90 XS SW |
20th Aug 2020 10:59am |
Yes definitely!
If it is a Defender Td5 ECU you are using, then you need: Defender Td5 controller: M.501 Td5 loom adapter: H.501 This gives you a setup like this: Click image to enlarge You may need the rev counter wire adding from the ECU to the Td5 speedo plug: W.551 1988 90 Td5 NAS soft top 2015 D90 XS SW |
15th Oct 2020 1:36pm |
oneten10 Member Since: 15 Oct 2020 Location: balikesir Posts: 2 |
Thanks Martin , for your quick reply,
what the difference, 2.2 cluster vs 2.4 cluster? my service said me "2.2 cluster will not work , buy a 2.4 cluster." if You sure it will work, could you tell me the price of your gauge controller. how can buy , can U send to Turkey? |
15th Oct 2020 2:12pm |
2.2 and 2.4 have different CAN messages, and normally use a different fuel sender (2.4 is the same as all previous Defender sensor).
But we fully support both 2.2 and 2.4 clusters on a plug-and-play basis with our looms. I'm 100% sure it will work!! More details in our web shop: https://www.fnltd.co.uk/shop/puma-gauges-controller-c18.html Any more information you need just ask! 1988 90 Td5 NAS soft top 2015 D90 XS SW |
15th Oct 2020 2:57pm |
mkenya Member Since: 29 Nov 2015 Location: nairobi Posts: 1 |
Any idea when these will be available again?
20th Jun 2022 12:10pm |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2877 |
PM inbound
20th Jun 2022 12:46pm |
Later this summer I'm hoping to get a product back on sale again. It's been an utter nightmare with chip shortages - not even just limited in availability, absolutely zero availability since mid last year. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
20th Jun 2022 12:50pm |
