![]() | Home > Tdi > Brake fluid warning light - MOT failure |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 ![]() |
What about your handbrake light?
Same light for both handbrake and fluid level is it not? Maybe just handbrake switch at fault? |
90roy Member Since: 21 Jun 2016 Location: Middlesbrough Posts: 130 ![]() ![]() |
Never thought of that srod. Where is the switch located? 300tdi 90 1996.
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 182 ![]() |
Does it not come on when the engine is cranking, not when the ignition is on but the engine isn't running? I'm pretty sure on my v8 it does that.. |
No it doesn't Jonny.
I had to check just now though.. 300tdi 90 1996. |
It's at the base of the handbrake lever, possibly under the rubber gaiter, so an easy one! Does your your handbrake light come on, when the handbrake is on...? |
Actually no it doesn't srod.
I'll have to strip it down tomorrow and have a look. Thanks. Roy 300tdi 90 1996. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
The brake fluid warning light doesn't come on with ignition to test. It only comes on if the brake fluid is low or the handbrake is on
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2732 ![]() ![]() |
It should come on with the starter crank as a light test. There is a relay that performs this function, wiring diagrams will show it.
The handbrake switch was not fitted to most Defenders, only higher spec models. |
My parents 300 definitely doesn't and hasn't failed an mot because of it
As stated there is a relay that performs this function, shown on this wiring diagrams see the link
https://www.defender2.net/gallery/albums/u...le0006.PDF |
Thanks guys.
Where will the relay be located? In fuse box area in the cab or engine bay? TIA. Roy 300tdi 90 1996. |
fuse box area in the cab i think 4 one from left hand side
Many thanks for the help and suggestions.
I found a corroded wire to the handbrake cable which was the issue. It definitely helped me knowing where to look / start which made this a relatively easy fix. Roy 300tdi 90 1996. |
EuropeDefender Member Since: 02 Apr 2018 Location: Tuscany Posts: 11 ![]() ![]() ![]() |
Hi.
My 300 hasn't any test light function. Only glow plug light. Si Vis Pacem Para Bellum |
