Home > 130 > 130 Sill Tanks |
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 |
I ended up getting the safari equip ones for my 130, diesel down one sill and water down the other. Would have preferred these though! @tab.travels on instagram
Defender 130 2.2 TDCI Defender 90 TD5 80" CCV Trialer 4.6 V8 (14CUX) Stage One V8 109 - 3.5 V8 Stage One V8 109 - 4.6 V8 (GEMS) - in progress Range Rover L322 4.4 TDV8 Freelander 1 2.0 TD4 |
14th May 2020 6:13pm |
Here's the best pic I have to hand showing the safari equip ones, you can see the extra filler on the side. Sits at the same height as the chassis, never bashed them yet and done plenty of off-roading. Might help someone down the line
Click image to enlarge @tab.travels on instagram Defender 130 2.2 TDCI Defender 90 TD5 80" CCV Trialer 4.6 V8 (14CUX) Stage One V8 109 - 3.5 V8 Stage One V8 109 - 4.6 V8 (GEMS) - in progress Range Rover L322 4.4 TDV8 Freelander 1 2.0 TD4 |
14th May 2020 6:25pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2075 |
I MAY - and I mean MAY be interested in fitting a one for water to my 110 but it all comes down to cost etc ...
I had a great sill mounted tank on the previous 110 which Dormobile made but sadly they don’t supply them any more ... Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7712 |
cheers for these, do you have any more pics of them fitted or can explain the plumbing to the main tank please? presume you fill both separately, then pump from aux to main tank? Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
24th Dec 2020 5:15pm |
Ngala Member Since: 26 Oct 2020 Location: Germany Posts: 2 |
Hello,
I am close to purchasing from SE sill und under bench tanks, but they don't provide a lot of info. Can anybody elaborate what their experience is with those tanks. I would like to install also some rock sliders from a different company and wonder if they might get into each others way? Cheers |
15th Mar 2021 8:06pm |
Anything ever come of this? Cheers
6th Jun 2023 8:28pm |
