Home > Puma (Tdci) > Clutch switch and throttle responce
Page 1 of 3 123>
slocum
Probably many of you had already tried to disconnect the clutch switch, as used on td5 engine, and discovered that... nothing happens!
I've done some tests and I've discovered that the clutch switch on Puma engine works the opposite way than td5 switch. This means that it's a normally open switch and its disconnection is completely aimless. The right way to "disconnect" this switch is to shortcut it.
After done this I couldn't believe I was driving the same car! The "acceleration tail" completely disappears and the throttle finally responds as it would!
Maybe this solution might be useful for defender affected by "running on" of throttle too. I hope you will appreciate my experience.
Goodbye!
JS
Post #4251 16th Oct 2008 8:50pm
mse
Might this have something to do with the 2 different throttle settings.
High has little movement and low has full travel. Mike
Post #4252 16th Oct 2008 9:05pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Is there anything like this that can be done to the TD5 and if so, how do I do it?? I am always trying to improve anything on mine until the warranty runs out, then I can do the other bits I want!!!
Thanks
Landy nut
Post #4253 16th Oct 2008 9:25pm
jst
on a td5 the plug that goes into the top of the clutch m/c controlled the anti shunt, ie it held engine revs when you dipped the clutch to 'aid' smooth changes. in reality if you can drive its bloody annoying. disconnecting it stops this.
it seems from above that the it on the tdci it need to be disconnected and then the wires joined to effect the same mod. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #4254 16th Oct 2008 10:03pm
slocum
On Tdci you can join the wires without disconnecting them from the clutch switch. I simply put a t-tap between them.
On Td5 engine you must unplug the connector from the clutch switch.
Post #4255 17th Oct 2008 12:53pm
mse
So what does this actually give you real terms? Mike
Post #4258 18th Oct 2008 5:01pm
slocum
Now, when I close the gas, it actually closes immediatly. With normal setting, expecially in Low range, it takes a second before it actually closes.
Post #4260 18th Oct 2008 5:36pm
mse
Mine is instant to Mike
Post #4263 18th Oct 2008 7:10pm
Landy nut
Sorry to be playing to idiot card here chaps, but when you talk about closing and gas etc, I get lost.
Could someone give me in idiots terms, what benefit doing this would have to my TD5???
Is it s throttle response thing or it is a faster pick up thing or what??
Sorry to ask the obvious question, but I just dont get this one.
Thanks
Landy nut
Post #4264 18th Oct 2008 7:40pm
mse
Im understanding it to be put foot on clutch to change up and the revs build whilst foot is off the go peddle and on the clutch Mike
Post #4265 18th Oct 2008 7:42pm
slocum
I'm sorry, I assumed that you already known this practice on Td5 engine. Not so easy for me, but I'll try to explain.
In normal conditions, when the clutch pedal is released, the ECU, to avoid shoks to the transmission, has a very slow response to the stepping off of the gas. If you can drive, this slow response is really aimless and annoying, mainly in off road driving.
When the clutch pedal is pressed, and this slow response becomes no longer helpful, the ECU cut the gas instantly. That's why many people use to disconnect the clutch switch on td5 engines.
I apologise for my ugly english! I hope you understand anyway. Rolling Eyes
Post #4268 18th Oct 2008 10:43pm
mse
I dont think the TDCi is the same Mike
Post #4269 19th Oct 2008 10:05am
Tim_NZ
Australia
From the TDCi workshop manual:
"The clutch switch is located on the clutch master cylinder. The clutch switch is a pressure transducer type. When the clutch is depressed the clutch switch sends a signal to the ECM (engine control module) which reduces engine torque."
Tim
Post #4270 19th Oct 2008 10:22am
slocum
mse, no, it isn't the same. Have you read the first post? On td4 (unlike td5, where disconnecting the switch is enough) you must shortcut the wires. The td4 switch is a "normally open" switch, the td5 switch is a "normally closed" switch. But this is the only difference. The behaviour of both engines is very similar.
Post #4271 19th Oct 2008 10:41am
mse
No what i meant was - i dont experience the symptoms of the TD5 on either TDCi's i had - so i dont think there is any point to messing around.
Further - there is a difference in how the throttle response is on the TDCi against the td5 - as mentioned above, low has a different map on the throttle than high - so again i dont think there is any point Mike
Post #4272 19th Oct 2008 12:29pm
Page 1 of 3 123>
