![]() | Home > Maintenance & Modifications > Changing rear discs. Anything else worth doing? |
greenlandrover Member Since: 09 Jul 2017 Location: Stourbridge Posts: 145 ![]() ![]() ![]() |
As the title says, I need to change rear pads and discs.
Just wondering if it's worth doing anything else while it's all off? Cheers, Jason |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Replace your wheel bearings and convert it to the tdi type with 2 big nuts!
Cheers Greeni and Bear100,
Whats the difference between the Puma and the Tdi ones please? |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
When mine was done the other week I got new rear drive flanges,
Much better no 'nock' when you come off the power. £16 each side for Oem |
I haven't got time at mo to explain, but found this, sorry
![]() https://forums.lr4x4.com/topic/57761-td5-wheel-bearings/ |
AndyT66 Member Since: 19 Sep 2016 Location: Bedford Posts: 149 ![]() ![]() ![]() |
I did the two brake mudshield plates, they were 14 years old mind and very flakey
Thanks for the link Greeni
![]() AndyT66 thank for that tip. The ones on there are looking a bit rough. |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 ![]() |
Go down to the local breakers and buy two 300tdi disco or 300tdi 90 halfshafts and fit them instead of the two piece ones.
I did take all 4 off, I didn't see a point keeping them. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I've had a quick nosey around the web and can't see the difference. How do the Puma ones differ to the Tdi ones please? Which bit is the two piece part? Excuse my ignorance ![]() ![]() Cheers, Jason |
The late td5 / Puma half shafts are two piece with separate drive flanges - these flanges and shafts always wear and get slop in them causing the usual driveline bonk. Landrover sorted this problem out on the 300tdi's with the one piece halfshafts with integral drive member, but for some reason went back to the two piece shafts in early /mid 2000's, possibly to rationalise and use th same halfshafts as the 110 when they ditched the Salisbury. I think they may have reverted back to one piece shafts again with the late pumas?
Ive had four late td5's and a Puma and swapping to the 300tdi shafts is always the first thing I do to them when I've bought them and it is always a big improvement even if they don't seem that worn. Here's a link to paddocks but breakers are full of them and can't give them away usually! http://www.paddockspares.com/ftc3271-rear-...lange.html |
Thanks Lotus_esprit_s1
![]() You learn something new every day when owning a Defender! ![]() Sounds like a good idea to change them whilst doing the brakes ![]() Cheers |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1237 ![]() ![]() ![]() |
Um 300Tdis weren't integral shafts, certainly not on 110s and Salisbury axles. Seperate drive flanges and shafts, should know as I've currently got them sat in the shed. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
I was referring to 90's as the original poster has a 90.
