![]() | Home > Maintenance & Modifications > Clutch Spring mod |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
I came across this mod tonight, is it worth doing and can you do it to a 1990, 90
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
If your pedal currently has the long coiled spring fitted, you will need a later clutch pedal. Good mod though, done it to the soft top
Here you go. The search function is your friend:
http://www.defender2.net/forum/topic6616.h...spring+mod Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
I fitted a Britpart clutch assist thingy the other month, one of the better upgrades/mods i've done.
It's one of those 'why didn't I do this earlier' type situations. TD5 Defender 90 Discovery 3 HSE |
I have checked and unfortunately have the old style clutch pedal
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2326 ![]() ![]() ![]() |
It's dead easy to swap for the later type.
Thanks, do you change the pedal or the whole unit
Would this do the job
http://www.ebay.co.uk/itm/Land-Rover-Defen...SwU8hY7pXZ |
That would do it. Yup, swap the whole assembly out.
Thanks Mo, would I need the modified spring for this unit, the spring on it kinda looks similiar to the uprated vesion .h
No, these pedals are already fitted with the spring.
You don't need to change the clutch master cylinder over either, you can use your existing one. ![]() ![]() |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Did mine last weekend no spring on it at all, much better after and the tie wraps worked a dream
