Home > Maintenance & Modifications > Tripmeter (Brantz) Fitting
KPNuts
England 2010 Defender 110 Puma 2.4 USW Alpine White
Has anyone fitted a trip meter into a Puma? We have a Brantz and want to fit it in our Puma - will the Brantz Interface Sensor work? If it will, what wires does it tie into? There being no workshop manual for the puma means I do not know which wires are feeding the speedo.
(I could not find anything on this topic when doing a search)
Thanks
Keith 2010 110 Utility Station Wagon
1996 110 Station Wagon
Post #54341 21st Jan 2011 12:45pm
TRR Motorsport
United Kingdom 2010 Defender 90 Puma 2.4 ST Galway Green
Hi Keith,
I've always used Branz wheel sensors so have no knowladge of the interfaces. I try to keep things simple but they're not much use on a 4x4.
It might be worth having a word with your freindly neighbourhood service manager. I bet they'll have a diagram to hand that'll give you the signal feed wire. "If it ain't sideways, you just ain't tryin'!
Post #54346 21st Jan 2011 1:33pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
i know boab fit them all the time, they are back from morocco now, i know on the td5 its the yk (pin 1) on the speedo plug 2004 TD5 Defender 90 xs station wagon
Post #54607 22nd Jan 2011 9:26pm
