Home > Technical > Indicator fault
Chris90V8
England 1987 Defender 90 2.5 TD XS CSW Portofino Red
Indicator fault
Has anyone had this problem?
Changed my indicators to leds and now the left will come on the same time as the right (vice verse)
Have changed the relay for a wipac led one and also have tried a new hazard switch!
All worked fine before, so what on earth have I done?
Is this a known fault or quirk?
Any suggestions welcome... Racking my brain here Crying or Very sad
Chris
Post #587349 24th Dec 2016 9:58am
V8GPC
do you have dash LEDs or lamps.
On early dash boards its a single lamp for left/right indicator (2 green arrows); the system works by discharging in both directions through this lamp. If you put an LED dash bulb in place it sort of links both circuits and they both come on when you indicate.
You either need to update the dash where they have separate indicator warning lamps... or replace a couple of your LEDs back to bulbs. (sometimes the side repeaters can be kept as lamps)
Post #587710 26th Dec 2016 4:47pm
Chris90V8
Thank you for your reply....
The Defender is an 87 model, so yes...an early model.
Hoping to dedicate a lot of time to this problem tomorrow.
Will put your idea in place and see what happens...
....fingers crossed
Chris
(Anyone got a newer dash for sale?) Bow down
Post #587719 26th Dec 2016 5:06pm
V8GPC
Post #587775 26th Dec 2016 7:59pm
Chris90V8
...think you have just made my Christmas
Bow down Bow down Bow down
Chris
Post #587784 26th Dec 2016 8:23pm
Chris90V8
Update...
Searched google and found some valuable info:
Ordered a RDX warning light from Bolt-on-Bits (this has an earth wire) and have been assured that this instantly solves the problem with no fuss.
(wish this issue was made more aware to owners of early defenders / Land Rover 90's etc when purchasing led indicators, has caused hell in all headaches and time wasting!) Evil or Very Mad
Cost �15 and sent out 1st class - same day
...will update when delivered and installed.
Chris
Post #588112 28th Dec 2016 11:19am
Chris90V8
Just arrived in the post Thumbs Up
...fingers crossed
Stand by Rolling Eyes
Post #588657 30th Dec 2016 12:46pm
V8GPC
still standing by - just curious to see if all is ok now Thumbs Up
Post #589030 31st Dec 2016 7:23pm
Chris90V8
...gonna try tomorrow if I can.
Been side-swiped with the "Lurge"! Sad
Post #589127 1st Jan 2017 9:16am
Chris90V8
YIPPEEeeeeeeeeeee
IT WORKS ! ! !
led / diode light fitted...
Might get some sleep tonight now, all thou my binnacle mount broke! Big Cry
(Will be ordering from Raptor Engineering tomorrow)
...gonna be one of those 'Money Pit' projects Rolling with laughter
Chris
Post #589410 2nd Jan 2017 12:28pm
V8GPC
Post #589438 2nd Jan 2017 2:45pm
Chris90V8
...going to buy a good quality product
(Fed up buying twice) Big Cry
Wish they had a emoji with 'cash flying away' Laughing
Post #589537 2nd Jan 2017 8:19pm
