Home > Technical > Programme a new key Fob
Coolcamper55
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
I mamaged to lose my set of keys in the mud last week and now only have the one set Sad .
I managed to get new keys cut from the local high street and have got a hold of a key fob Lucas 17TN type.
The fob needs to be programmed but how?
I have looked round the web and just got myself more confused.
Is there someone on this forum who has done this and has a surefired method.
Very grateful for any help, if there are concerns re security please PM me.
Thanks
Tommy Tommy
110 XS TDCi
Post #52597 12th Jan 2011 7:51pm
PM sent
Post #52606 12th Jan 2011 9:13pm
CFB
Anyone who has just bought one of the Nanocom Evolution units should be able to do this for you Thumbs Up Andy
Post #52610 12th Jan 2011 9:29pm
mse
And worryingly there are a few us...once again sorry for starting the thread Whistle Mike
Post #52614 12th Jan 2011 9:49pm
Lorryman100
As far as I am aware they can only be programmed through the AS10 module meaning you need to take it to the dealer or to some one who lives local to you, with a shiny new Nanocom evolution unit who would be willing to help you Whistle
Now who on here stays close to the Greenock area with a nanocom Whistle
Post #52674 13th Jan 2011 1:14am
Merlin
Can anyone point me towards the link for programming an integrated key, using a Nanocom? Just can't seem to find it.
Thanks ,
Merlin
Post #97753 2nd Nov 2011 7:46pm
Lorryman100
IIRC,
Go into the 10AS module with the ignition off. Find plip learn and have all your plips at hand. Start plip learn and press the lock button on the plip until the horn sounds and/or the hazards flash, this plip has been learned. Also this has to be done with no RF interference, so you may have to move the vehicle to get the plip and 10AS to communicate. Do the next plip straight after the previous one has been learned, up to a maximum of 4. You have to relearn all the plips when you do this otherwise only the new one will work as that is the only one learned. Once all the plips have been learned click on finish/write settings. Try all the plips. Thumbs Up
Brian.
Post #97838 3rd Nov 2011 1:47am
Merlin
I know I'll probably regret this as being too easy a question, but what does "PLIP" stand for?
Merlin
Post #97901 3rd Nov 2011 3:18pm
T1G UP
Merlin
Put Lightly In Pocket
Post #97902 3rd Nov 2011 3:22pm
Isn't it the generic sound that a lot of car alarms make when armed? Press the button and 'plip'.
Not on Defenders (or any Land Rovers) though. Darren
Post #97920 3rd Nov 2011 5:15pm
Lorryman100
Did you get the new plip working?
Post #99442 11th Nov 2011 10:30pm
Merlin
Yes and No!
After many attempts I've ended up with the old ones working (again) and the new one can lock and unlock the car. However, when I tried to use it to start the car it didn't work. I wonder whether it is something to do with the corrupted file as mentioned on the Nanocom website. But, when I connect the Nanocom to my PC (no external power supply connected at that time) I can't get the Nanocom to be recognised by the PC. I have tried it with a second computer, but it is exactly the same.
Any suggestions?
Merlin
Post #99494 12th Nov 2011 12:14pm
SteveNorman
Not all 17TN keyfobs are the same.
YWX101220 which is the correct part number for a defender has a built in immobilser chip as well as the radio transmitter.
YWX101200 is a freelander 2001 on keyfob which hasn't got the immobiliser chip.
If you have the latter, it will work the central locking/alarm, but not the passive immobiliser.
If programmed for the alarm.central locking & is working, the immobilser chip should work also.
Regards
Steve
Post #99498 12th Nov 2011 2:22pm
Lorryman100
Merlin wrote:
Yes and No!
Any suggestions?
Merlin
Did you upgrade the nanocom to the BBS software? Does the nanocom light up with the external power supply connected and powered up? Also did the garage re instate everything in the 10AS once they found the pin fault?
Brian.
Post #99507 12th Nov 2011 3:32pm
Merlin
Far as I know the AS10 is working fine. The Nanocom is lighting up an d says it's connected. The thing is the PCs don't recognise the device.
Merlin Sad
Post #99784 13th Nov 2011 9:44pm
