Home > Maintenance & Modifications > Worklight for the defender
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Hey guys I just bought myself the rear worklight for the defender but it didn't come with any instructions (Part No. - RTC8921AA). I know its a simple job to setup but any instructions would get me started Big Cry
Cheers guys. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #52026 9th Jan 2011 7:36pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
fit a switch in the rear right hand speaker panel and take feed from connector behind panel, thats how i did mine Thumbs Up
Post #52032 9th Jan 2011 7:45pm
there is already a 12v feed behind the rear speaker panel (purple +ve, black -ve), why not put a 12v relay over the reversing light and use the 12v feed, that way you can effectively use the reverse switch to switch on and off.
I have one of these instead, 12v rechargable, magnetic, has hooks too.
Post #52150 10th Jan 2011 10:40am
kingofthesparks
If yoy put a tree position switch in you can turn it on or off or have it so it comes on with reversing light via relay. Thumbs Up
Post #52164 10th Jan 2011 12:27pm
Glynparry25
Have you purchased part number RTC8921AA from Land Rover? The reason I ask is because if you have it comes with full fitting kit, relays switches etc included in the sale (and will have fitting instructions
Glyn Sheep
Post #52172 10th Jan 2011 1:22pm
landydubai
United Arab Emirates 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Fitting
Think I still have the instructions I fitted one in Nov
Let me see if I can dig it out
Tom LandyDubai
Keep the shiny side up!
09 110 XS BAS remap
09 90 pick up BAS remap
08 D3 V8 G4 Spec
Bentley Speed GT 2009
G55 2003
Ford Raptor 2010 - new toy!
Post #52192 10th Jan 2011 3:33pm
Merlin
Hi there,
I noticed the same problem (no instructions), which I thought for the money was ridiculous. The power pick-up is behind the rear offside trim, that is found if you take off the rear speaker trim. I modified the light with an extra wire so I could have the light coming on when reversing. So much better as the Defender reversing light isn’t up to much. You’ll supposed to have a warning light to let you know that the work light is on, but I don’t think it’s a legal requirement and I doubt if you will fail an MOT because of it. I would attach the diagram I used, but I don’t know how to do this, so if you PM me I’ll send it to you.
Merlin
Post #52194 10th Jan 2011 4:09pm
lrdxb110
@kingofthesparks
@bpman
^^thanks guys I'm going to give it a try!
@Glynparry25 - that is correct mate got the whole lot of fittings, switch, wiring etc. but no fitting instructions bought it brand new from my local land rover dealer in london lookers park royal and when I got back to dubai there were no fittting instructions Big Cry
@landydubai - that would be great mate, cheers. I don't want to give it to al tayer and get it fitted and pay 300 aed/hour for labour Whistle
@merlin - PM sent! '08 LR Defender 110
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #52234 10th Jan 2011 7:52pm
mse
Lots of replies, but guys all the instructions are ONLINE Thumbs Up Whistle
Remember the reverse light isnt part of the test Mike
Post #52240 10th Jan 2011 8:27pm
Glynparry25
Unless they are stuck on Wink Thumbs Up ... a bit picky I know Whistle
Glyn Sheep
Post #52251 10th Jan 2011 9:10pm
lrdxb110
Mse pls could you tell me where they are online?
Cheers. Thumbs Up '08 LR Defender 110
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #52889 13th Jan 2011 11:27pm
landydubai
http://www.ownerinfo.landrover.com/extfree2viewlrprod/index.jsp LandyDubai
09 110 XS BAS remap
08 D3 V8 G4 Spec
G55 2003
Post #52892 13th Jan 2011 11:39pm
landydubai
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm LandyDubai
09 110 XS BAS remap
08 D3 V8 G4 Spec
G55 2003
Post #52893 13th Jan 2011 11:43pm
mse
Re: http://topix.landrover.jlrext.com/topix/vehicle/lookupFo
Thats the one...changed a while ago Mike
Post #52894 13th Jan 2011 11:44pm
Whem wiring up work a light, especially if connecting it to the reversing light circuit, remember that:
1) it is illegal to have a bulb of more than 21W in a reversing light,
2) a reversing light must either be switched on/off automatically by the selection/deselection of reverse gear or if worked off a manual switch there must be a warning light (which can be in the switch or seperate) to indicate that it is on
3) a rear worklight cannot legally be illuminated on a public highway unless it is only used in conjunction with an amber warning beacon or amber strobe system.
A lot of folk don't realise this last one, but I have never heard of anyone being done for this.
A trick I quite often do (particularly due to the need to lock a combination padlock on a gate after exiting at night) is to select reverse in the main gearbox and neutral in the transfer box with the engine running, so the reversing light is on to allow SWMBO to close and lock the gate without me having to keep a foot on the clutch.
Post #52897 13th Jan 2011 11:48pm
