Home > V8 > Vac advance |
Iggle piggle Member Since: 10 Sep 2014 Location: Wales Posts: 378 |
Yes only the one vac pipe needed, the other port is a vent I think
19th Oct 2016 8:07pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 |
Is that the one that comes out the front of the vac advance or the rear next to the distributor connection? 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
19th Oct 2016 8:40pm |
From memory the vac pipe goes on the one pointing away from the distributor,
But I'll check tomorrow |
19th Oct 2016 9:19pm |
Great, thanks Iggle Piggle 1999 Land Rover Defender 110 td5 station wagon
19th Oct 2016 10:01pm |
Sorry Charcoal, I forgot all about this,
Click image to enlarge as I thought it is the port pointing away from the distributor & there is nothing on the other one |
25th Oct 2016 9:06am |
No problem, same setup as mine then. mine has a plastic box thing half way down the vacuum line that I believe is a vacuum delay, yours doesn't appear to have it though. Will try taking it out and see if anything improves. 1999 Land Rover Defender 110 td5 station wagon
25th Oct 2016 1:12pm |
Yes that little valve is to delay the vacuum advance when the throttle is snapped open,
I was told & also read in the link below they can give more trouble than they are worth so when I replaced the vac pipe I didnt fit it & put it somewhere safe, needless to say if haven't seen it since! http://www.gomog.com/allmorgan/regulator.html is your not running right after the rolling road session? |
25th Oct 2016 2:23pm |
Interesting, will get rid of the valve also. The carburettors have been tuned well on the rolling road, the misfires and high idle turned out to be caused by something in the ignition system. I've replaced the distributor first as the old one is very warn and the rotor arm has a good few centimetres of play. then I had to swap them back because I had a loose piece of swarf in the new distributor which killed the ignition module. Finally got a new module and getting round to refitting the new distributor again. 1999 Land Rover Defender 110 td5 station wagon
25th Oct 2016 2:49pm |
Putting the new dizzy in seems to cure all problems except the misfires around 80mph. Not a problem though as I rarely need to go that speed. 1999 Land Rover Defender 110 td5 station wagon
28th Oct 2016 2:12am |
