Home > My Defender > Defender 90 LS/6L80 conversion. step by step!
Page 1 of 9 123456789>
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
I have a put a few posts up in a couple of other threads on this but thought it may be of interest to people to see what is involved.
I am converting my 2001 TD5 Defender 90 to use the 6.0 l77 (ls) and 6l80e automatic from a 2015 VF holden Commodore SS.
This will take a while to complete (maybe before Christmas if I am lucky ad it all goes to plan)
So this is the 90 in question. It is my offroad toy. This is a late 2001 90, which I have owned for nearly 14 years, buying it with 11000miles on the clock.
My wife thinks it would be more sensible to do the swap into our 2.2 90 and on the odd occasion I drive it I am inclined to agree with her.
Spec list is pretty long so I wont bore people with that, but the main points are Underdrive, cage, lockers, up-rated driveline, galvanized Chassis etc etc.
In no way is this a shiny, straight and polished Defender. It has been off road all over the place including Tasmania, Europe, a lot of Australia including the Simpson Desert, and Cape York. A fortune has been spent on maintenance over the years however due to the nature of its use.
And this is where the powertrain has come from, Its a 2015 VF SS Holden commodore. which has only done 37k km. Believe it or not this is written off.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #564037 15th Sep 2016 2:30am
psimpson7
So, next steps.
Getting it home, complete with BCM, ECU, Throttle, cats, loom, gearshifter etc etc. I may/will not use it all but I wanted it to make sure I wasn't missing anything
Luckily now there is an off the shelf adaptor available out of the states that allows the LT230 to be fitted onto the 6l80e. The ability to keep the LT is very important to me as I have an Ashcroft Underdrive
This is the adaptor. Also in the pic in the background you can see various parts for linkages and gearlever mounts.
I continued to collect parts. Below is a Lokar shifter:
Truck (4WD) Sump as the car sump isnt suitable:
2014 90 XS SW 2.2.
Post #564038 15th Sep 2016 2:36am
psimpson7
Most of these conversions are being done in the US. One issue over here is the fact that almost all the engine/box options are out of cars. That means that they have an output housing that isnt any use as it has a prop shaft flange bolted on the back.
So the next step is to convert it to a 4wd (and dry) tail housing
Seal is also fitted in this image (core plugs also fitted in the holes at the top and bottom):
Threaded section cut off! and 4wd tail housing fitted
Trial fit of the adaptor:
I then removed the aircon compressor and started a test fit in the 90:
2014 90 XS SW 2.2.
Post #564039 15th Sep 2016 2:46am
Pickles
Brilliant.
Pickles.
Post #564048 15th Sep 2016 6:08am
psimpson7
so the next steps...
The alternator is low on the passenger side of the engine I needed to move this. Also with this been a very late l77 they dont actually have a power steering pump on the engine. Its electric. The holes are still there however to run a pump if requried.
I ended up buying a kit from Kwik Performance which relocated the alternator to the top of the engine on the passenger side, and also allows the fitment of a GM type 2 PS pump
This is with the pump and pulley fitted
Mounts were next. The Transfer case mount on the drivers side bolts straight back on, and with an earlier Defender the std mount can be used on the adaptor for the LT aswell. On the TD5 this wont work easily. You could cut off the chassis mount and drill and then bolt on the earlier mount with the round rubbers but I didn't want to do that.
Luckily a mate has a CNC machine , and I have Solidworks so we made some custom mounts out of 6061 alloy billets
Adaptor side:
Engine ones. LH and RH versions of this (the steel work for the chassis part of the engine mounts is being cut at the lasers as I type this!)
I however made up the one for the adaptor by hand:
For reference this is what the shifter will look like when its fitted in the car. It will fit through exactly the same rubber boot that the r380 lever did
2014 90 XS SW 2.2.
Post #564049 15th Sep 2016 6:13am
psimpson7
ok, next, Exhaust manifolds.
The car manifolds are cast and quite compact. Unfortunately not quite compact enough.
Not very good comparison photo of the overall manifold size between the factory ones and the replacement ones
Reduction in flange offset:
Passenger one fitted (hard to get a pic of the other one due to stuff in the way):
One downside to these is the fact that the flange is a different angle to the originals which makes it hard with the catalysts. more on that and wiring next!
2014 90 XS SW 2.2.
Post #564052 15th Sep 2016 6:22am
psimpson7
Ok wiring and stuff....
This was probably my biggest worry. I need to run the full emissions setup for the engine with cats, pre and post cat 02's EVap, fuel tank pressure sensor etc etc.
Speartech in the US can provide me with a stand alone loom for the engine and 6l80 with the exact spec I need. I placed the order yesterday and the turn around should be around 5 weeks. I need to send in my ECU and TCM.... the ECU is easy, The TCM not quite as much!
So the issue with the Auto is that it has the tap up/tap down on the gear shift on the left gate. When people fit these engine and boxes in Patrols and the like they tend to run the factory commodore shifter which I didn't want. The Lokar shifter I have only has one plane (i.e no push across to the left for the tap up/down functions)
I need them on a separate switch as part of the new loom setup.
So, the TCM needs reprogramming...
And its inside the auto.
So, sump off
Remove valve body/TCM assembly and strip this down so only the brown bit will be sent:
Inside the auto with the stuff removed: (old sump is back on for now)
I have just posted those off to the States....
So that's about where I am at the moment!
I have a new deeper sump on order, the wide mouth filter from a Camaro / 6l90e box, along with the Lokar throttle to suit the setup (the guys who are pioneering this stuff in the States aren't far off being able to use a std td5 pedal which will save a decent amount!)
2014 90 XS SW 2.2.
Post #564054 15th Sep 2016 6:34am
psimpson7
Pickles wrote:
Brilliant.
Pickles.
Thanks Pickles! 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #564055 15th Sep 2016 6:35am
JOW240725
Great work! You make it seem so easy but I'm sure it's not!
Looking forward to the finish! Thumbs Up James
Instagram @suffolk_rovers
Post #564058 15th Sep 2016 6:54am
Nice!
Watching with interest.
I'm in the middle of the wiring stage on my GEMS engine and it's a pain.
If I knew then, that I know now, I would have gone for the LS route, they're really simple to wire in!
Post #564069 15th Sep 2016 7:35am
davew
Really like that alternator bracket, not seen that before. Is your power steering pump one with a combined reservoir ? Trying to figure out if I'd need to change to a remote reservoir to fit that bracket...
One thing I'll point out to you now, just in case, the inlet manifold is symmetrical and I've found that having the throttle body sticking out of the front and makes fitting the air intake pipework, especially with a snorkel, very difficult. If you have room between the back of the engine and the bulkhead (I'm guessing you will have to fit the transmission in) it's worth considering turning the manifold through 180 degrees so all you need is a simple 90 degree pipe to route the intake either to the original grill or to a snorkel to either side.
I didn't know about that when I fitted mine in 2007 and it cost me a lot of time and money to route/fabricate the intake as a result. It's been on my list of things to "fix" ever since !
 http://www.yorkshireoffroadclub.net/
Post #564169 15th Sep 2016 1:10pm
L110CDL
Thanks for the thread, watching with interest, great read Thumbs Up Clayton.
Keeper.
Post #564312 15th Sep 2016 8:02pm
psimpson7
Thanks Dave,
The pump I have does have a remote reservoir but I believe they do a number of brackets, including one to suit the pumps with the attached reservoir.
I am aware of the space issue with the inlet. The loom I have ordered takes into account the reversed manifold and one of the next jobs on the list to turn it around!
Rgds
Peter 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #564330 15th Sep 2016 8:28pm
Pickles
Mr. Simpson,...more "brilliance"!!...Where & how did you learn the skills,..what do you do for a dollar?
Top stuff, Pickles.
Post #564369 15th Sep 2016 10:00pm
psimpson7
Hi Pickles,
Mechanical Engineering is my background, and I am still in that industry.
In terms of how I learnt, I was lucky growing up and learnt a lot of stuff from my Dad on our farm in the UK, and I have a habit of just trying things and see what happens. I've had heaps of cars over the years that have required 'dedicated' ownership including a Caterham Superlight R and a Lancia Delta Integrale Evo so I am used to getting stuck in!
Some of this project has been quite easy so far, but some has been quite hard!
I have spent the last 2 hours with the entire bulkhead wiring loom in bits in the front room removing the 10as unit and associated wiring, the now redundant OBD2 port and its wiring and as much stuff as I can that I think I wont need. I think I have about another 10 hours work to go on that! I wonder if I may get frustrated and just start a new loom, but I don't particularly enjoy wiring so I will see how I get on! 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #564466 16th Sep 2016 11:45am
