Home > Africa > 1995 Defender v8 |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
If you look underneath an LT77 will have two drain plugs
23rd Aug 2016 8:03pm |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 941 |
Mine is an LT85, I want to know what gearbox they came out the factory with in South Africa. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold 1985 Land Rover 110 ex mod project Tithonus ~ Sold |
23rd Aug 2016 10:55pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2604 |
feedback from local forum:
"Easy way to tell is the position of reverse – if it’s towards the driver and back, it’s R 380" -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th Aug 2016 1:19pm |
I haven't got access to a South African Defender to check for myself. I'm asking for someone in South Africa who has access to a '95 Defender v8 to see what gearbox is used. If it was that easy I wouldn't need to ask 1999 Land Rover Defender 110 td5 station wagon
24th Aug 2016 3:46pm |
by all accounts, it's the R380:
From 1994 the Defender had either the 300TDi or the 3.5 V8, in South Africa only. Both had the then new R380 gearbox. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
24th Aug 2016 5:00pm |
I see, thankyou 1999 Land Rover Defender 110 td5 station wagon
24th Aug 2016 6:33pm |
gerudman Member Since: 13 Sep 2016 Location: Cape Town Posts: 8 |
It should most certainly have a R380. All CSW variants had them.
13th Sep 2016 7:10pm |
Thanks for letting me know, would you happen to know the gearbox number too? 1999 Land Rover Defender 110 td5 station wagon
13th Sep 2016 9:35pm |
