Home > Td5 > Best battery....
TOP5N
Best battery....
Hi all. I need a new battery for my 2001 td5 90. It has a few gadgets fitted, in the way of led light bars, audio, cb etc... Can anyone recommend a good battery, and also whether it is round or flat terminals, as i haven't taken my bucket seat out yet to take a look
Regards,
Chris
Post #541126 17th Jun 2016 9:21pm
BigRuss
If it's a single battery your after what about an Odessey PC1750, I believe they have round SAE terminals so almost a straight swap.
Someone will be along to confirm Thumbs Up Russell
2011MY 110 XS USW Black
Post #541147 17th Jun 2016 10:11pm
TOP5N
Thanks, I'll look it up
Chris
Post #541148 17th Jun 2016 10:16pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I have used VARTA batteries for the last 15 years, never had any problems with them and seem long lasting.
Post #541153 17th Jun 2016 10:51pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Good deals optima red tops at the moment, have found them to be indestructible over the years
Post #541159 17th Jun 2016 11:06pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
+1 for optima. Good strong battery 2002 110 td5
Post #541183 18th Jun 2016 7:04am
jst
For normal usage I wouldn't bother with special needs like optima, odyssey etc.
Numax, enduroline leisure batts from Tayna will give a good 900cca, 100ah for around £75. Numax cf31 iirc will fit. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #541185 18th Jun 2016 7:38am
Mo Murphy
I'd agree with JST, Numax/Enduroline are a good quality, good value for money battery.
50 Shades of Pennine Grey
Post #541217 18th Jun 2016 11:11am
miker
Whatever's on offer with a 3 year warranty! Whistle
Post #541219 18th Jun 2016 11:22am
Merlin
Post #541234 18th Jun 2016 12:31pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
If you have a Costco card, then the Bosch batteries - S5 or S6 I think - are a good price and the warranty is 4 years.
Simon
Post #541243 18th Jun 2016 1:01pm
gilarion
Any good named battery with at least 3 years warranty, but go for a battery with the highest Ah capacity with the highest Cold Cranking Amps you can find. The standard defender batteries are usually 70 Ah, but go for at least 100 Ah and possibly 110 Ah. And with at least a Cold Cranking Performance (Amps) of 850. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #541248 18th Jun 2016 1:12pm
Raywin
United Kingdom 2001 Defender 90 Td5 HT Java Black
About a year ago I put a Hankook calcium battery on my TD5, good warranty, very good price and seem to be well regarded brand now, early to tell but I it seems to have massive reserves of power.
Measured up and put the biggest one which would fit, then sat it on a thin polystyrene tille about 6mm thick.
One tip is to look for a reputable scrap yard locally, took my old battery to Ripon and received a £10 bonus towards my new battery, ever little helps. Ray
Post #541254 18th Jun 2016 2:09pm
shipbadger
United Kingdom 2011 Defender 110 Puma 2.4 HCPU Galway Green
I see you're Gloucester based. You could try contacting Battery Megastore in Tewkesbury for a price. I've bought the last half a dozen or more batteries (no, not all for the Land Rover), there and been happy with them. I noticed they had Optima batteries in a display when there the other week getting a new battery for my Transit based motor home.
Tony Comber
Post #541273 18th Jun 2016 4:24pm
sako243
Regarding the Bosch batteries. I installed one in the FF as there is limited space in the compartment and they came highly spoken of in fullfatrr.com.
Well several months later it was working fine but ended up dropping it a bit hard on its corner when I removed it and cracked it. Needed a replacement quick and popped down the local hardware place (has a lot of stuff being in West Wales) and bought, I think it was, a Yuasa of the same spec. Half the price and in the cold months turned over the 3.6 far more readily than the Bosch. Since then others have reported similar feelings of being underwhelmed by the Bosch batteries. Particularly at their price.
Got a 019 100Ah 1000CCA battery from my local Manbat supplier for the 110 for just over £100 and it has been superb so far (8 months or so). Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #541299 18th Jun 2016 6:39pm
