Home > Group Buys > Nanocom Evolution Group Buy |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
NANOCOM EVOLUTION GROUP BUY
 Hi all, I’m thinking about running a Group Buy on the Nanocom unit from Blackbox Solutions (a forum sponsor). This post is really a ‘run it up the flagpole’ type affair to start with, mainly to gauge interest levels and to determine if it will be viable (worth it). Discounts are available on kits, accessory items, additional cables and licences (but does not include remap for Discovery 3 TDV6) I’ll focus on the TD5 and Puma, but the deal will also include units for Discovery II (TD5, Motronic V, P38 (GEMS, EDC, Motronic) and CAN BUS Freelander, Disco 3 and 4, RR Sport 05 - 09, RR Sport 10 - 13 and RR L322 10 - 13. I’m sure I don’t need to go over the benefits of this unit, but some main points are highlighted below (clicking the hyperlinks will take you to current documentation with full explanation). For a full breakdown of what it can (or can’t) do, have a look at their website http://www.nanocom-diagnostics.com or feel free to ask here and i’ll try and answer (if I can’t, i’ll happily contact BBS and ask on your behalf). Defender TD5 - TD5 Engine Management System - TD5 Map a flashing function to remap the programmable type ECU's. Full of functions and features, the TD5 engine management software offers reading and clearing of fault codes, the read and write of certain settings including Injector codes. Viewing of Live data, checking of Outputs and putting the ECU into learn mode for the security coding. You should note that there are 2 variations of the TD5 ECU, MSB denotes a non programmable version where the later NNN can be programmed using the Nanocom Evolution. - Wabco ABS system (up to 2010) Functions include Read and Clear faults, View Inputs and check various Outputs on the ECU and you can also use the Nanocom Evolution to bleed the primary and secondary hydraulic circuits. - Lucas 10AS Alarm (up to 2010) The 10AS alarm will read and clear triggered events, allow you to view various settings and data as well as make and save changes to the data.You have a choice of Inputs again to see live data and can also test certain outputs to make sure the alarm is working as it should. Finally you can also program the PLIP/Fob (not the key) to the ECU. Puma 2.4 & 2.2 - Puma 2.4 & 2.2 Engine Management and Instrument Pack The functionality of the Puma Defender engine management and Instrument pack is quite limited in what is actually available to read and change but we are working to add flashing of software to these ECUs. Functions include reading and clearing of faults, changing of settings such as Speed limit (not removal), Fuel tank volume and Tyre size are available. You also have the option to view Inputs which is live data being transmitted from the ECUs. - Wabco ABS system (up to 2010) Functions include Read and Clear faults, viewing Inputs and the check of some Outputs on the ECU. You can also use the Nanocom Evolution to bleed the primary and secondary hydraulic circuits. - Lucas 10AS Alarm (up to 2010) The 10AS alarm will read and clear triggered events, allow you to view various settings and data as well as make and save changes to the data.You have a choice of Inputs again to see live data and can also test certain outputs to make sure the alarm is working as it should. Finally you can also program the PLIP/Fob (not the key) to the ECU. Discounts 1 - 4 kits = no discount 5 - 9 kits = 5% discount 10 - 14 kits = 10% discount 15 - 19 kits = 15% discount 20+ kits = 20% discount Further savings can be made by paying in their base currency (which is the Euro) and by using an app/bank which gives true interbank exchange rates and no currency conversions fees. I’ll go into this further if the post looks positive. Don't forget, as a forum sponsor, a 10% discount is already there for the taking. This means we'll need to get interest in up to 15 kits Process - Interest gauged (sign up) until July 31st 2016 - If successful, i’ll contact BBS with details (I will need what you want to buy, your full name and email address via PM) - I give you a special discount code and you purchase through their website (no money comes my way, you pay them direct) - They post out by DHL and usually arrives within a couple of days. I’ll double check, but this isn’t UK only. They will post to Europe and Worldwide As always, there are other alternatives on the market which may, or may not be better. You can do your own research on this - but the nanocom does seem to be overwhelming accepted as the best of breed unit in the Defender community. More than happy for thoughtful, helpful and constructive posts, queries and suggestions. We are all grown up, so no blatant anti-BBS diatribe please. I do not work for these guys, just very happy with their product and use it on my TD5 (and soon my discovery 3). I get nothing out of this other than the same discount as offered. I do the leg-work, you get the discount. I’m genuinely just nice like that The one caveat is the offer will only be open to members of the forum with a joining date prior to this post (to stop people signing up just for the discount). If i've missed anything or you have any questions, please leave a message here or PM me. Ta Ben TD5 Defender 90 Discovery 3 HSE Last edited by huffhuff on 19th Jun 2016 10:22am. Edited 1 time in total |
14th Jun 2016 12:41pm |
Hi Ben. Count me in for a TD5 defender kit.
14th Jun 2016 7:44pm |
Will do TD5 Defender 90
Discovery 3 HSE |
14th Jun 2016 8:37pm |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 259 |
I would be interested in a Puma 2.4. 2008 Defender 110 XS CSW
Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
19th Jun 2016 10:42am |
Super duper @swollock. If you could click the button at the top it will help in keeping everything together and then messaging should it all go to plan.
Cheers TD5 Defender 90 Discovery 3 HSE |
19th Jun 2016 11:06am |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 706 |
Hi Ben, Thought it was worth mentioning I purchased a Nanocom Evo via the LZ group buy you ran last year, it arrived promptly and with all the extras specified so thank you very much for sorting it all out
I'd like to add the Discovery 4 unlock pack code NCOM54 and also the screen suction mount NCOM30 please? I presume I'd also need the Canbus lead NCOM24 to connect up to the D4 or does it come with the unlock kit? Harry |
20th Jun 2016 10:21am |
gtmotorsport Member Since: 29 Jun 2016 Location: Cornwall Posts: 97 |
Very interested in a Defender TD5 package if this group buy has sufficient interest to go ahead.
29th Jun 2016 10:36am |
Hi guys, obviously the saving won't be quite so good as before Brexit. But there is still a saving to be made and a bit more if you pay in euros.
You can also use a banking app on your smartphone, which gives true interbank rates and no currency transfer fees. Last time I bought something, paying with the free app actually saved an extra £51ish in various fees and exchange rates. I can PM anybody interested with details of the app. It's actually really good to use if you travel lots. You pre-load it with money and exchange to the right currency free and at great rates. You then don't have to use your credit or debit card. It's a mastercard so comes with full backup and security etc.. You can have a 'digital card' and they post a physical master card too. TD5 Defender 90 Discovery 3 HSE |
11th Jul 2016 4:07pm |
Leaky 110 Member Since: 12 Jul 2016 Location: Glasgow Posts: 62 |
Just joined the forum and noticed this post. I'm in the market for a nanocom or similar, if this is still a goer id be happy to make up the numbers.
12th Jul 2016 7:39pm |
Charles Member Since: 04 Sep 2013 Location: Dudelange Posts: 16 |
Hi
I actually have a Faultmate msv2 with Disco 3 license from my previouse car. What do you think? Is it better to change the license on the faultmate to a Puma 2,2 or to sell the faultmate and going for a nanocom evolution? Best Regards Charles |
16th Jul 2016 5:47am |
Telshe Member Since: 02 Jul 2015 Location: West Oxford. Posts: 49 |
Hi Ben
Count me in for one. Telshe |
20th Jul 2016 9:06pm |
daingeanrob Member Since: 21 Dec 2014 Location: sligo Posts: 27 |
count me in for one for a defender td5 03
21st Jul 2016 2:34pm |
cont my in for TD5 kit
21st Jul 2016 2:45pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
Click the sign up button guys (available on the full not mobile site at the moment) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
21st Jul 2016 3:28pm |
