Home > Td5 > Defender TD5 cruise control.....confused! |
I’m guessing that question was aimed at me. I made the switch, no one sells one at the moment. See my build thread below for a couple of pics how I did it. Ray
6th Aug 2018 7:01pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2280 |
Thanks for the link, but there’s 67 pages on that thread!
Can you tell me what page it’s on? Cheers. |
9th Aug 2018 10:07am |
I’ve only done it recently so it’s on page 64, I took a black switch cover from my defender drilled a little hole for the light then put it on the discovery switch then pics of how I got the motorway decal on are on page 64 Ray
9th Aug 2018 5:45pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5745 |
Digging up and old thread here...Do all TD5's support Cruise control ? Mine is a Jan 99' model. 1999 Defender TD5 110
11th Mar 2019 8:52pm |
I think it’s post 2001 when they changed the ECU.
But not 100% sure. I fitted the Nakatanenga kit to my 2005 TD5 Defender and it works fine. The kit costs just over £100 But for some reason it’s not listed on the UK site, only the German one. The instructions are in German but they sent me English ones on a PDF file. |
12th Mar 2019 8:44pm |
Thanks lightening. A bit more research required. 1999 Defender TD5 110
14th Mar 2019 2:14pm |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 157 |
It should be an NNN ecu and not an MSB ecu. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
16th Mar 2019 12:08pm |
The cruise control has transformed long journeys in my 110. We recently drove to Scotland (a round trip of 860 miles) and it was great to set the speed at 65mph and then just steer. After slowing down you can just press the resume button.
I would say it’s the best accessory l have fitted. |
18th Aug 2019 2:40pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
FWIW... I have an 2000 MY and would love cruise as well but alas.... Its not cruise but this little mod made long distance driving a tad more comfortable by undoing one of the throttle springs. Its easier on the right leg. Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
18th Aug 2019 3:41pm |
I have modified mine as well, by drilling a new hole for the spring a bit further round, so reducing the tension.
18th Aug 2019 4:24pm |
18th Aug 2019 4:38pm |
[quote="lightning"]I have modified mine as well, by drilling a new hole for the spring a bit further round, so reducing the tension.
that’s how I started then I just realized it was two separate springs. So I decided to save myself the drilling 👍🏻 Its a good mod regardless 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
19th Aug 2019 1:40am |
Bim Member Since: 09 Jun 2018 Location: Cambs Posts: 28 |
Would like to do the cc mod but will it work with Roamer overdrive also if using a speed healer is this switched on and off with the cruise control
28th Jan 2021 10:06pm |
TheLastMaverick Member Since: 16 Apr 2017 Location: Nottingham Posts: 10 |
It should work with the overdrive with the speed healer fitted, overdrive only normally affects CC in 5th gear, but the speed healer will allow full use of CC.
The CC should not interfere with the workings of the speed healer. Mike |
29th Jan 2021 12:41am |
