Home > Maintenance & Modifications > Anderson Connectors
leeds
Anderson Connectors
I put a post up in reply about Anderson connectors a few weeks back.
Thought I would do another more expanded one. Would be grateful if people could proof read it, point out any mistakes, grammatical errors, areas for improvement etc
Thanks folks
ANDERSON 2
Anderson sockets are genderless, industrial DC connectors. There are different types of connectors made by Anderson Corporation (1). The Anderson connector typically used in the 4x4/overland world are the SB connectors
Genderless connectors have no plug and socket. Instead they use two identical connectors to form a connection. This can be seen in the Anderson connector cross-section below:
The name Anderson connectors has become a generic name just like Hoover has for vacuum cleaners
Generic/lookalike Anderson connectors can be of much lower quality than the genuine items. In particular the plastic mouldings and contacts may be substandard and may not necessarily be compatible with the genuine items. Poor quality electrical contacts may result in arcing across the contacts and could lead to a fire.
Anderson SB connectors comes in four different sizes, rated at continuous 50/120/175/350 amps but capable of carrying higher currents for shorter periods of time. The size typically used in the 4x4 world is the 175 amp SB connector which can carry much higher currents of up to a 1000 amps but only for short period of time. The 175 SB connector is typically used on jump/booster leads and winches. Less power demanding equipment, compressors/drills etc can be connected via the 175 amp connector, however some people prefer the smaller 50 amp connector for such equipment.
The different colours relate to advised DC voltage from 12V to 144v. They are mechanically keyed so that it is not possible to fit a yellow one to a blue one etc. This prevents 12 volt equipment being plugged into a 144 volt DC supply. The full colour code can be found here (2)
12volt is normally yellow
24 volt is red
36 volt is grey
Typically in the UK the grey one is used on Landrovers. However Warn winches use red ones!
Anderson also do a range of accessories for their connectors including handles, dust covers, PVC boots
Anderson recommendations for crimping or soldering can be found on their website. Either an electrical indent cable or a hexagon hydraulic crimp can be used.
Home garage crimping methods may result in inadequate crimping and/or excessive flash. Likewise trying to crimp a tube connector onto too smaller a cable can result in excessive flash which can cause problems.
If access to a proper crimp tool is not available they can be soldered on as well. The best method is probably by using a plumbers blow lamp with the electrical tube contact held in a vice. Half to 2/3 fill the tube contact with solder. If using a heavy duty electrical soldering iron the Anderson tube contact may have to be clamped using some thermal insulation material to prevent excess heat loss into the vice.
Strip the insulation off the cable to be used to the length of the tube contact. Tinning the cable is recommended using good quality solder. Use damp (not wet) tissue to prevent the cable insulation melting. Then lower the tinned cable into the molten solder in the tube connector .
Do NOT be tempted to crimp a soldered joint as this could result in the solder fracturing causing electrical contact problems
Heat shrink tubing can then be applied to the joint.
If connecting small diameter wire to a 175 amp Anderson connector (i.e. compressor/drill etc) then some care has to be used in handling this connector to avoid the cables breaking
The Anderson connectors can be mounted in many positions on a vehicle both inside and outside. Typically the master Anderson connector on a Land Rover Defender is mounted on the front of the battery box. Whenever cables go through a panel it is wise to use a rubber grommet to reduce risk of electrical problems. Attaching extra large size cables to battery terminals can be awkward dependent on the battery clamp. A battery clamp with a 8mm stud can overcome this problem. However care must be taken that the positive terminal can not short out on the battery box cover. Insulating the underneath of the battery box cover and the positive terminals is good practice.
or like this
If fitted outside the vehicle cabin it would be wise to use an isolation switch, a red rubber dust cover and a black PVC boot. Standard position for an external Anderson connector is either on the front bumper or under the rear cross member However with a bit of imagination other positions can be found. There are two standard sizes for vehicle isolation switch, 100 amp or 200 amps.
Typically a 100 amp isolation switch is rated up to 500 amps for 5 seconds whereas the 250 amp switch is rated at 2500 for 5 seconds (4)
Jump leads/compressors/'cordless' drills/work lights etc can all be fitted with an Anderson connector
Please note it is up to the user/installer to ensure that all the equipment/cables etc are correctly rated and fused and is installed according to best practice.
References:
http://www.andersonpower.com/products/
http://www.andersonpower.com/products/colorcode_mp.html
http://www.andersonpower.com/products/use.html
http://ripca.com/
Post #45884 21st Nov 2010 10:14am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Good guide - if using smaller wire sizes use a reducing bush - the pdf in the link below gives a gude to sizes
http://www.andersonpower.com/litlib/files.html/download/495
Post #45887 21st Nov 2010 10:37am
leeds
Thanks for your input Cobs Thumbs Up
Brendan
Post #45893 21st Nov 2010 1:29pm
discocuzzy
Great Overview guys Thumbs Up You cannot teach stupid people to do clever things
Post #45900 21st Nov 2010 4:26pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Thanks very useful.
Nothing constructive to add but OMG that last picture, what's he powering off that?
Steve
Post #45914 21st Nov 2010 8:19pm
leeds
Steve B that last photo was taken in Estonia. In the Baltic countries they were only allowed one winch in challenge events. Solution was a demountable winch with power supply available at front and rear of the 110.
Will be tidying the post up and putting it on our website.
Have a few ideas for some other information leaflets.
Brendan
Post #45920 21st Nov 2010 9:19pm
alantd
Very thorough!
Only one grammatical correction:
"Home garage crimping methods may result in inadequate crimping and/or excessive flash. Likewise trying to crimp a tube connector onto too smaller a cable can result in excessive flash which can cause problems."
I think should read "...onto too small a cable...". No?
Also, I see your references at the end but it would be super-helpful if you could create some inline links. I know you probably don't want to officially recommend specific suppliers of grommets, cables, heat shrink etc (esp as they'll be country specific) but perhaps if not inline then a short paragraph at the end with links to suppliers that you use?
A very good post, though. Thanks Thumbs Up One that started out as a 2.4 TDCi 110 XS
Post #46009 23rd Nov 2010 9:11am
Which is .... ?
Post #46010 23rd Nov 2010 9:40am
BigMike
Post #46024 23rd Nov 2010 11:59am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Re: Anderson Connectors
leeds wrote:
is this cable 25mm or more ?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  www.newfoundland.gr
Post #111673 3rd Jan 2012 11:18am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Great stuff, thanks !
I'm also a user of these Anderson connectors since many years and can only recommend them Thumbs Up Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #111710 3rd Jan 2012 1:44pm
Good document Brendan, more ideas Thumbs Up
Post #111711 3rd Jan 2012 1:47pm
pom
top info!
Post #111724 3rd Jan 2012 3:06pm
Eduardo
Thanks Leeds for the info.
Very useful.
Regretably nobody provide andersson connectors here in Chile Evil or Very Mad
Cheers Eduardo
Post #111730 3rd Jan 2012 3:26pm
MK
neither Branston Pickel Thumbs Up Puma 110" SW
Post #111782 3rd Jan 2012 7:35pm
