![]() | Home > Maintenance & Modifications > Scangauge...who has one.... |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
K9 has one here is the link
![]() scroll down http://www.defender2.net/forum/topic3719.html?highlight=scangauge NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Do a search and you will get all the inspiration you need! A 'Blendmount kit' is what you need! Another two threads on the same subject?????? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
![]() Here I have mine. Vinicio |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I have one in my Puma.. Mounted just in front of the cubby cup holders. Purposely put there so the thieving scrotes don't get tempted to pop a window and remove it for me!
I made a small pcb type plug to replace the huge OBDii plug as supplied.. Saves having to pop the diagnostic port off its mounting bracket.. Here's a link to the piccies over on the "other place".. ![]() ![]() Paul. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Car't see the pics ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
haworthj Member Since: 01 Nov 2010 Location: Sussex Posts: 178 ![]() ![]() |
Hey Vinicio.
That's exactly where mine landed too. I have to say I like it. |
Paul, Have you any details about how you made the new plug?
Jimbo |
OOPS... seems that you need to be logged into "the other side" in order to see the pics.. I used a program called Sprint Layout to design the board.. The actual board was made using some copperclad fibreglass PCB, and etch resist transfers, with the etching done in ferric chloride.. Sounds complicated, but it's really easy to do.. The hardest bit was ripping the OBD2 plug apart without destroying all the connections inside.. The good thing is that I now have the correct internal pinout for the plug. I'll knock up a PDF next week if anyone's interested in making one. PAUL. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Here you go...sorry for pinching your pic
![]() I'm interested ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
me too. But this looks far too complicated for my pea brain. Would you consider fabricating one for me? I'll buy you some fine wine?
Defendit Member Since: 01 Nov 2010 Location: Down Under Posts: 26 ![]() ![]() ![]() |
Thanks for posting. It made me focus on the problem of the OBD plug which has been bugging me for a while. I simply bought an OBD plug - http://www.jaycar.com.au/products_uploaded/productLarge_9718.jpg Inside there is a PCB which saves making one. Did not fancy cutting up the original scangauge cable so I also bought a Cat 5 Ethernet patch cable which fits into the scangauge and simply cut off one end and wired that to my new plug. All done in an hour and no more removing the speaker every time to access the OBD. ![]() |
Shax, have you done a pdf file? If you have can I have a copy? Ordered a scangauge today, so should come next week sometime and this would save me removing the OBDII socket. I have some cat5 ethernet patch cables already and just need to order a OBDII socket. Also is this the correct wiring for the Puma: Pin Signal Description 2 J1850 Bus+ 4 CGND Chassis ground 5 SGND Signal ground 6 CAN High J-2284 7 K-LINE (ISO 9141-2 and ISO/DIS 14230-4) 10 J1850 Bus- 14 CAN Low J-2284 15 ISO 9141-2 L-LINE (ISO 9141-2 and ISO/DIS 14230-4) 16 +12v Battery power |
Hi all, sorry for not delivering the PDF as promised.. Bloody computer had a meltdown.. Still trying to get access to the files needed.. As soon as I get into the drive, I'll get it sorted.. failing that, as soon as I get a free weekend, I'll see if I can get the photos, and diagrams made up from scratch again. PAUL. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
