Home > Puma (Tdci) > Water ingress
Page 2 of 2 <12
Dieselhead
Just had my winscreen replaced & I purchased a new seal from L/R
The guy from Autoglass said it was better than the one which came out
You could see where the water had come in when the screen was removed Shocked I watched him do it Thumbs Up
plenty of sealent pumped in with new seal & touch wood alls been OK Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #240325 1st Jun 2013 8:58pm
Happyoldgit
Taking it to a dealer is no guarantee that the problem will be fixed as sometimes they cannot or do not replicate the circumstances under which water gets in. Fixing leaks in Defenders can sometimes mean several trips to the dealers and even then people have had to DIY. Steve.
http://forums.lr4x4.com
Post #240328 1st Jun 2013 8:58pm
K9F
Dieselhead wrote:
Just had my winscreen replaced & I purchased a new seal from L/R The guy from Autoglass said it was better than the one which came out Thumbs Up
The issue of dirt collecting under the seal is very well documented and unless the dealers remove the screen (which they are very reluctant to do as there is a risk of breakage) the cause may never be cured. Read the link posted in the quote below from over 18 months ago for more information.....
K9F wrote:
Thud,
Ignore any 'doom mongerers' you have no worries whatsoever, also get the seal off and the area thoroughly cleaned. I had two replaced in short succession by Autoglass and it is an ideal time to get the crud cleaned out under the seal and get it sealed correctly.
My advice would be to be in attendance and read carefully the issue of dirt ingress in the thread below, especially my posts and Fekete's on pages 1 and 2....
http://www.defender2.net/forum/topic2126.html
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240332 1st Jun 2013 9:02pm
Page 2 of 2 <12
