Home > Technical > Wipac Crystal headlights - which version?
Page 1 of 3 123>
dantastic
I want to upgrade the headlights to wipac crystals. But there seems to be 2 versions available. One at roughly £30 and another at £65. There's a little cover in front of the bulb on the more expensive one. What else??? Which one to get?
http://www.paddockspares.com/pm678-wipac-c...ralia.html
http://www.ebay.co.uk/itm/WIPAC-7-CRYSTAL-...0566991399
Post #500723 5th Feb 2016 8:17am
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Get the ones from paddocks.Also get nightbreaker bulbs.
You can get stainless steel bezels too, a worthwhile mod as the originals are s*** Thumbs Up
Post #500725 5th Feb 2016 8:26am
As above but with Philips Extreme bulbs. Whistle
Mr. Green
Post #500740 5th Feb 2016 9:32am
dantastic
Right, that's a saving - but what's the difference between them though? Is it just that little cover in front of the bulb?
Post #500745 5th Feb 2016 9:37am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I have both versions (now boxed up in the garage, as I current have LED´s fitted). The ones without the cap came from a reputable supplier and were listed as Crystals, but are obviously not. They look and worked fine. Excellent beam pattern and no corrosion or other issues.
The ones with the caps came in a Wipac box, and, as mentioned here, were more expensive.
The caps don´t seem to make any noticeable difference to the performance negative or positive....but they do , in my opinion, look better.
The cap is probably supposed to immitate the classic "Lucas tri-pod" look, seen here, I suppose.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #500756 5th Feb 2016 10:14am
dantastic
Ok, so between them, which would you recommend as you have both?
I think I like the cap, I think it looks good.
Post #500760 5th Feb 2016 10:23am
I've had the SVX type on my td5 90, they are also on my 110 now and I'll be fitting them to my v8. It's worth getting the stainless rings too.
Post #500768 5th Feb 2016 10:42am
Lost for Words
Mr. Green
I strongly suggest neither. See below what I've just posted on another thread:
Quote:
Cupboard wrote:
Osram Nightbreakers are well reviewed (and effective) high output 55/60W headlamp bulb. They sacrifice longevity for higher output.
Acually, they're not. As Osram's own figures show, Night Breakers emit the same luminous flux as their Original Line bulbs! This is pretty much the case with all the upgrade bulbs. To be legal, they have to stay within the regulations; their standard bulbs will reach the limits of these regulations, and so the upgrade ones are simply not brighter and are a complete waste of money that won't last as long.
A "whiter"/"bluer" bulb is often perceived as brighter, because we are much more sensitive to colour temperature than luminous intensity, but a "whiter"/"bluer" light is not actually beneficial to our vision either and is nothing more than a fashion statement, and let's face it, no-one gives a damn about the colour of anyone elses headlights!
Halogen bulbs will not colour match LEDs without a very severe loss of light so forget that. If you want the best vision, bulb life and value for money, stick with standard halogen bulbs.
Thumbs Up
 Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #500821 5th Feb 2016 1:05pm
williamthedog
My nightbreakers have been on truck for 5 years , rattled off road , down bumpy tracks, they aint blown yet
Post #500833 5th Feb 2016 1:21pm
Lost for Words
Yes, but they do have shorter lives by nature, not due to weaker design. Thumbs Up Visiting from DISCO3.CO.UK
Post #500835 5th Feb 2016 1:37pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I put Philips x-tremes in my standard lamps as soon as I got my Defender in 2009, as I'd used them in the one before - never had to replace them, so they are in their 7th year, approx. 40K miles.
Definately a slight improvement over the originals I took out (and keep as spares in the cubby), so for the extra few £, a no-brainer.
Standard colour (I didn't want blueish tinge).
Post #500842 5th Feb 2016 2:03pm
gilarion
Taken from Osram’s Nightbreaker’s data sheet:
Highest luminance: up to 90% more light than standard halogen lamps
Fatigue free, comfortable driving
Optimum light for more reaction time
Up to 35 meter longer beam of light (compared to standard halogen lamps)
Up to 20 % whiter light (compared to standard halogen lamps)
Various tests have been carried out on Nightbreaker bulbs by Auto Magazines using laboratory conditions utilising sophisticated measuring devices the test below was carried out by an independent for Auto Express and cleary shows the difference between standard and Nightbreaker bulbs
Osram Nightbreaker unlimited = 101.25m/26M (332/85ft) - 3260K
Osram Standard, = 95,25/25,25m (312/83ft) - 3050K
I have Osram Nightbreaker’s fitted and can clearly see the difference over standard bulbs.
As your evidence contradicts these findings could you tell us where your facts are substantiated from. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #500843 5th Feb 2016 2:05pm
Lost for Words
Osram's very own data sheets:
Original Line
Night Breaker Unlimited
ECE specs restict the maximum permissable luminous flux so there is no legal way of getting around it. As stated, observed improvements with the human eye are down to the perception of colour temperature vs luminous intensity, since we are all useless at judging the latter. There will be very slight differences in beam due to the smaller filament that are also used to their advantage and results in the above Auto Express figures but that is a tiny difference, and light is lost elsewhere to achieve that. Thumbs Up Visiting from DISCO3.CO.UK
Post #500862 5th Feb 2016 2:44pm
Lost for Words
Just to fish out the relevant figures:
Original Line H4
Luminous flux: 1650/1000 lm +/- 12/15%
Lifespan B3: 300/1100h
Lifespan Tc: 500/2400h
Night Breaker H4
Luminous flux: 1650/1000 lm +/- 15%
Lifespan B3: 80/300h
Lifespan Tc: 160/500h
Post #500866 5th Feb 2016 2:53pm
Wild Card 90
I totally agree. The ones with the cap, the orignal Wipacs. Thumbs Up 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #500869 5th Feb 2016 3:01pm
Page 1 of 3 123>
