Home > Td5 > Spare wheel bearings - what's needed...?
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I want to carry a couple of spare wheel bearings, apart from the bearing itself, what else do I need in order to change one..?
cheers
simon
Post #477699 30th Nov 2015 5:07pm
dorsetsmith
FTC 4785 seal and RFD 100000 stack nut for a start
Drive flange gasket (hub gasket) 571752
Post #477707 30th Nov 2015 5:21pm
rallysteve
-A 52mm socket and a big bar to get the old hub nuts off (assuming you have the later staked nut type, if not the box spanner type affair will do);
-17mm socket to get the drive flange nuts off
-pry bar/soft faced mallet to break the seal with the drive flange and hub and remove/install the hub seal;
-punch and hammer to remove the outer bearing races;
-Suitable wheel bearing grease;
Assuming you are travelling on an overland trip to want to carry spare bearings, in which case a stub axle would be advisable too.
Steve[/list] 02' 110 TD5 Double Cab Rebuild Thread
Post #477722 30th Nov 2015 5:53pm
couplands
cheers guys, just what I wanted to know...Wink Thumbs Up
Post #477728 30th Nov 2015 6:18pm
jst
plus 13mm multi point to remove the caliper bolts and spare caliper bolts, tube of RTV and grease to pack bearings with
personally i wouldnt use a stake nut, i would carry the two nuts with washer to bend over them to hold in place. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #477737 30th Nov 2015 6:41pm
dorsetsmith
personally i wouldn't use a stake nut, that right Idea
one big torque wrench 210Nm Whistle
Post #477790 30th Nov 2015 8:56pm
jst
i prefer the older method and ability to reassemble in the field without needing new parts like a stake nut. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #477813 30th Nov 2015 10:06pm
dorsetsmith
your right if i was filled striping and rebilding wheel bearings
FTC3185
FRC8700 or RFD100000 and TFC 3179
Post #477817 30th Nov 2015 10:15pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I changed to the old system too.
I allways carry a tube off blue silicon to seal anything except the fuel system as you need gray silicon for that. Smile
 Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #477880 1st Dec 2015 7:52am
davew
You might also want to consider changing to oil lubricated bearings - more prone to leaking but also much less prone to "catastrophic" failure. You need to use the RTC 3511 seal on the hub if you do this though as the "greased" seal doesn't provide a good enough seal to keep oil in (or water out). http://www.yorkshireoffroadclub.net/
Post #477894 1st Dec 2015 9:04am
Alien
Australia
I changed to the two nuts and locking tab but retained the original spacer.
Just did the first nut up as tight as I could with the tools I carry in the Puma.
Lock tab and second nut as per the normal method.
Undoing the stake nut on the side of a track would be big ask, I don't carry 3 foot of pipe to slip over my hub spanner.
I carry 2 bearings, hub seal, flange gaskets, spare lock nuts with washer, spare lock tab plus grease.
The reason for the spare nuts in case I damage one or need to fit bearings to another vehicle on a trip. Cheers,
Kyle.
Post #478030 1st Dec 2015 6:16pm
yetiman45
England 2005 Defender 110 Td5 CSW Blenheim Silver
The problem with keeping the spacer is you can't take up any play in the bearings when they wear, if you're using the old system of locking nuts and tab washer, just bin the spacer.
Post #478276 2nd Dec 2015 10:45am
Alien
Australia
I had no movment after a full clean and regrease on all 4 wheels with the spaces fitted.
If I do get any movment I'll take your advice and remove the spacers Wink
At this stage they are no worse than doing one nut up stupidly tight. Cheers,
Kyle.
Post #478374 2nd Dec 2015 5:04pm
landy andy
I've got the parts to convert to twin nut system if you want.
Also four timken bearings, one old bearing race altered to install new bearings, couple of oil seals, 52mm box socket.
Let me know if interested
Andy
Post #478663 3rd Dec 2015 11:09am
