Home > My Defender > My XS 90
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
My XS 90
Hi there chaps, I’ve had the car for just over 2 months now. I've done just over 2700 miles in the beast, no problems yet, its all ok apart from being a little bouncy (Might be something to do with the 19" disco wheels) Whistle
My mods so far are, hub adaptors to fit the disco3 wheels on (Cheers Dad), JVC head unit with built in DVD player, remote screen for DVD player and laptop, upgraded the standard speakers and added a sub and last but by no means least, Bell Auto Services have done a remap, speed restrictor removal, EGR blanking and put a de-cat pipe on Twisted Evil I'd like to say thanks to Pete at Bell Autos for sorting it out, great improvement Bow down Thumbs Up
There a few pics off my phone in my gallery "Stumpy" Mr. Green The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #2656 7th Jul 2008 7:59pm
sib
CarlS
Looks good. How do you rate the JVC ? What speakers did you fit and it all a straight swap over with no extra head unit leads needed ?
cheers
sib Sib
Bath UK
1952 80 inch
1973 88 inch
2018 Morgan plus 4 narrow body
Post #2665 9th Jul 2008 7:04pm
CFB
I'd like to upgrade the audio in my 110 as it is crap!
Thinkin new CD tuner with 2 way speakers in the front but reckon it needs some bass, anyone fitted a sub that doesn't take up too much load space? Andy
Post #2670 10th Jul 2008 8:19am
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Upgrade to an Alpine unit which only takes ipod and radio as a source, brilliant unit even with standard speakers also went for an Alpine mini sub which fits under rear seats(110 utility} which makes the sound better, which for it's size good.
Post #2671 10th Jul 2008 9:31am
CFB
That sounds just what I am after, have you got the Alpine model numbers please? Andy
Post #2673 10th Jul 2008 9:40am
markalpha
Hi Andy
The head unit is IDA-X001 and the sub is SWE-1000. The sub can be a bit boomy from bass guitars so it needs to be wired into the sub output on the stereo, mine wasn't and it needs to be done. You can alter the sub woofer levels using it's own switch but it's easier using the head unit controls.
Mark
Post #2678 10th Jul 2008 5:45pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
I have got the same head unit as Markalpha, but also upgraded the front speakers to Focals and tried the then powered Alpine Sub, but to be honest found it not bassy enough in the 90 as there was nowhere to hide it and allow it to produce more bass, so changed it to a Pioneer TS-WX22A. Since I did that Alpine have released the SWE-1000 which appeas to be a similar product to the Pioneer.
It fits behind the front passenger seat on the wheel arch and is held on with yups of velcro.
Very happy with the sound now, but I would recommend upgrading the front speakers, the reason I went for the focals was they are a perfect fit in the existing holes Thumbs Up 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #2682 11th Jul 2008 3:38pm
AndrewS
This is what I have thrown into the Red Dwarf. Its removable as and when required.
Post #2689 11th Jul 2008 9:53pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I found this nifty little JVC powered sub-woofer which fits neatly behind the cubby. It is run directly off a Pioneer head unit with iPod connectivity (wired through to inside the cubby) and Bluetooth hands-free. It sounds surprisingly good. I think it helps that most of the sound is being produced up close in the cabin rather than way back in the cargo area.
[/img] 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2690 12th Jul 2008 1:54am
CFB
Fitted a new Kenwood CD Tuner today with some upgraded Pioneer speakers in the original front and rear positions. It still sounds rubbish, an improvement but only just.
I clearly need a sub so am thinking of the Alpine SWE1000 but Halfords have the older SWM1600 on offer at £99. I reckon both will fit under the middle row bench.
I think the standard tweeters are also colouring the sound quite badly, will look at upgrading them too if I can find the Focals anywhere. Andy
Post #2740 15th Jul 2008 5:54pm
Bogblaster
Hi CFB, try these people www.caraudiosecurity.com fast delivery and very reasonable. 2019 MY Disco 5 HSE Lux
2016 90 Adventure
Post #2756 15th Jul 2008 8:24pm
CFB
Strewth, £195 for 10cm component speakers Shocked
Not sure the rest of the setup justifies the expense TBH. Andy
Post #2758 15th Jul 2008 9:38pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Bogblaster wrote:
Very happy with the sound now, but I wuld recommend upgrading the front speakers, the reason I went for the focals was they are a perfect fit in the existing holes Thumbs Up
Which model of Focals did you fit front & rear Bogblaster?
There seem to be 10cm 100CA & 100CA1 on that site...
Did you need to modify the rear speaker cavity?
(I assume the LR supplied front & rears are the same size?)
It would be good to not have to find space for a sub - I wouldn't mind spending extra on good speakers like Focals if they boost the base a little - did you notice much of an improvement before fitting/turning on the sub?
Post #2764 16th Jul 2008 9:33am
solmanic
I upgraded the rear speakers before installing the compact sub and there was no noticable difference at all. Any upgrade to the small front speakers or tweeters will only improve clarity and not provide much in the way of a broader sound spectrum. There is simply no substitute for a sub-woofer in getting better bass and fuller sound. The compact sub was the only option I could see that didn't require me to steal space from somewhere and the improvement was seriously so good, I would recommend doing that before spending anything on the smaller speakers. 2007 Defender 110
Post #2765 16th Jul 2008 11:18am
Bogblaster
Ads 90, Sadly the Focals are not cheap, but the quality is awesome, the model I have is 100V2. They dont increase tha bass, they are only 4", but the clarity is much better and then the sub delivers the low frequency. Only replaced the front ones as the back ones are not component, just a single speaker. I see you are in the Cotswolds, so am I, PM me if you want to meet and hear it for yourself Thumbs Up
CFB, it depends how much time you spend in your truck, I do 15000 ish miles a year and I couldn't stand the tinnyness of the factory setup. 2019 MY Disco 5 HSE Lux
2016 90 Adventure
Post #2766 16th Jul 2008 7:02pm
