Home > Maintenance & Modifications > 200tdi Head Removal, Inspection, Refitting
Page 1 of 4 1234>
shaggydog
Hi guys,
Welp, today is the day that the head come off.
Overall quite a nice job, just a bit nerve racking at times. I used a combination of manual, Haynes book of suggestions and this pictorial http://forums.lr4x4.com/index.php?showtopic=30111
I was surprised at how easily bits came apart and the quality of everything. Most of the threads were clean and even had there original golden/zinc plating on them.
Anyway, Photos!
Turbo off and and intake off. All looks good though the intake for cylinder 4 was very oily and greasy
Bits coming off!
View overhead, all looks good bar cylinder 3 which I very heavily oily.
The Head. Now it seams cylinder 4 is very oily and I found the exhaust port was not sealing properly with some oil dribbling out.
More details to follow, I need to have some food because I am starving. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #456385 19th Sep 2015 8:11pm
shaggydog
Some more pics showing the head.
Firstly, the gasket. I found the leak- as expected it was Cylinder 4 to Push rod so yay it was definitely worth taking apart.
This however doesn't account for the coolant loss so investigation needed.
No.1 Cylinder
No.2 Cylinder
No.3 Cylinder
No 4 Cylinder.
We have got a bit of an issue.
I cant get 2 of the injectors out.
I don't have a slide hammer and giving them a wiggle with a spanner has yielded no results. Anyone got any ideas? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #456401 19th Sep 2015 8:53pm
shaggydog
Quick pics of the Bores.
They all look good though but it worries me that no 4 is so oiley.
Can still see the honing marks at 167k miles is fairly good.
4 Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #456412 19th Sep 2015 9:09pm
Fatboy Slim
Wales
Good work mate, I'd say from those photos you've definitely got gasket issues on no3 as well as 4 which from the looks of it is where your coolant is going
Post #456504 20th Sep 2015 10:05am
shaggydog
Ahh interesting.
Where do I need to look on No. 3 then as I don't seem to be able to spot it?
When I removed the head off the tiny hole between 3 and 4 was gummed up with what looked and felt like silicone sealant which probably hasn't helped.
Also, looking at the block, looks like there may be some slight scoring as there are maybe one or 2 shiny vertical lines per bore against the honing marks (which are still present which is good) but it doesn't feel any different to the rest of the bore feels nice and smooth.
Also, how can I check the block for cracks or issues?
I think the head itself is going to go away to turners to be done as there are some lumps protruding where the dead end waterways (seriously?) between the bores go, which combined with the leaking valve and stuck injectors is making me think its time to send it off. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #456524 20th Sep 2015 11:45am
Fatboy Slim
Wales
If you look at the picture of number 3, you can see where a patch of carbon has been washed just above the inlet valve. Same corresponding patch on the piston crown suggesting you're getting coolant in there. If you look at the 4th picture down from the top the section between 1oclock and 2oclock ay you're looking at that photo looks black where the firing ring of the gasket sits. Also the gasket looks as if it was on the verge of failing from the two coolant galleries between 2 and 3 on the turbo side of the engine but difficult to tell from pictures.
Post #456525 20th Sep 2015 11:55am
Fatboy Slim
Wales
With regards to the block, clean it up with a sharp scraper and some wet and dry on a sanding block. Clean it thoroughly with brake cleaner, make certain all the bolt holes for the head bolts are clean and tap them if possible. Have a good visual inspection of the block surface, if you've got a good quality straight edge check the face for any deformation diagonally from corner to corner and straight across. I don't think you'll find anything wrong with it
Post #456526 20th Sep 2015 12:02pm
Fatboy Slim
Wales
I'd imagine the valves just want a decoke and a lap in.
Post #456527 20th Sep 2015 12:04pm
shaggydog
Bow down Bow down
Thanks slim very helpful.
I still cant get the injectors out though Evil or Very Mad
I don't really want to tap them through from the bore side as they are very delicate but no amount of swearing, soaking in petrol and wd40 and tugging on them and spannering them will get them to release Evil or Very Mad
Out of interest, why are the coolant galleries full size on one side but restricted on the other?
And why is there a dead end in between the bores? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #456645 20th Sep 2015 9:32pm
shaggydog
After what I can only describe as an epic battle between willpower and stubbornness (I'll let you decide who is who) with the help one of my friends, 4 hours of sweat and lots of wd40 the final 2 injectors released.
It did cost some scraped knuckles, a few beers and I broke a adjustable spanner which is somewhat of an achievement.
The head has now gone off to Turner Engineering for pressure testing, inspection and if required re-manufacturing.
The injectors now out have been sent to a local diesel injector specialist for testing. The results were that the initial pressure was down to 180bar - given the set pressure is 200bar with a 5 bar tolerance ether way- they needed some work, but even so quite impressive for 23 years and 167k miles!
The decision has been made to recondition them and much to my shock and pleasant surprise you can buy them brand new - for £150 each mind Shocked
This is turning into a horrendously expensive month Big Cry Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #457847 24th Sep 2015 8:27pm
Retroanaconda
Let us know how the injector recon works out. Thinking of treating mine to a set when it hits 250k.
Don't worry about the cost, a 200Tdi is always a good investment. They're not making any more after all.
Post #457849 24th Sep 2015 8:33pm
Triggerfinger
Recon injectors are not cheep either west of Scotland engineering charges 80 quid a pop Rolling Eyes
Post #457863 24th Sep 2015 8:55pm
shaggydog
I must admit, having very quickly been very pleased with Miss Shaggydogs Td5, its not the same as my 200Tdi. I really miss it.
I still can't get on with the light throttle and the clutch is really light. But we shall see.
Typically, after searching for ages for a good condition 200Tdi 130 in blue with a pto winch and finding ether wrecks or nothing......This turns up Big Cry
http://www.ebay.co.uk/itm/1992-LANDROVER-D...2a5877cbc3
Miss Shaggydog has already said no though Evil or Very Mad
But yeah, it will be fine as long as I get paid at the end of the month Shocked Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #457867 24th Sep 2015 8:59pm
shaggydog
I know the feeling Big Cry
But, better than £115 from Turners or risking a "job lot" from fleabay.
The real highlight for me though was that parts are still available Very Happy Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #457874 24th Sep 2015 9:06pm
shaggydog
Oh :censored:
Welp, got a phone call from Turner engineering today.
The head is cracked on no 3 Inlet between the inlet and the water jacket. Cannot be welded as there is no access so basically the head is a write off. Big Cry
What a pain! What a faff! How Bothersome! or words to that effect were muttered today.
So, my options are...
1. Buy outright Gas flowed head from Turners at £720 ( Shocked )
2. Buy Second Hand Head from Foley Special Vehicles (£300) and then get it shipped to turners for possible news its no good (again Rolling Eyes)
3. Cut my losses and sell her without an engine NOT GOING TO HAPPEN
4. Look at Engine conversions -300Tdi? 2.8TGV? Cummins 6BT? When will it get done? costs? Will it work?
5. Any Suggestions?
So that's where I'm at at the moment.
Worst news is I'm still not getting on with the Td5. I keep stalling it and I have a feeling its clutch related as there is next to no biting point on it and it keeps stalling on me which is really annoying. I'm not a td5 expert so it could just be operator error, but it very much seems like the only way to pull away smoothly and consistently is to boot it. Which is hard to do in stop start A21 Traffic.
On the plus side my injectors should be back tomorrow Rolling Eyes Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #459348 30th Sep 2015 7:45pm
Page 1 of 4 1234>
