Home > Td5 > TD5 Anti Stall
excossack
TD5 Anti Stall
Do all TD5s have anti stall? Or is it just the ones with ABS ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #452804 6th Sep 2015 5:51pm
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Mines not got ABS & has anti stall.
Mind I still stall it!!! lol
HTH 2006 Defender Double Cab- Zambezi Silver
Post #452810 6th Sep 2015 6:05pm
excossack
How do you know the Anti Stall is working or maybe not working?
I can still stall it as well. Mainly from bringing up the clutch, 1st gear and not having enough revs (even with foot flat to the floor its slow to respond) 1999 Defender TD5 110
Regards
John M0VAZ
Post #452812 6th Sep 2015 6:07pm
davew
They all have it as far as I know, it doesn't operate when the clutch is in use though. One trick that we use in trials is to disconnect the clutch switch to prevent the anti-stall switching off when you cover the clutch. It can be quite frustrating otherwise as on steep slow ascents you cover the clutch as you crest the top and the anti-stall drops out and the engine stalls. http://www.yorkshireoffroadclub.net/
Post #452820 6th Sep 2015 6:24pm
airpusher
It's nowhere near as modern as the puma ones.
If you touch the accelerator when it's on the tipping point it'll stall.
You just have to slowly let the clutch up and it I'll start to crawl.
I'm sure somebody with far more technical knowledge will give more info. 2006 Defender Double Cab- Zambezi Silver
Post #452822 6th Sep 2015 6:26pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Find a step hill, stop at the bottom, select 4WD low range, select 1st gear (all with clutch in) Turn off your ignition, wait for a few seconds, release the clutch pedal, then turn the ignition on (without the clutch in, and don't touch the accelerator or brakes) your truck should climb the steep hill, even lose terrain/hill without any driver input other than steering.
Post #452823 6th Sep 2015 6:29pm
airpusher
That's interesting. I think that happens to me recently. Then I struggled to use the anti stall to start on the hill so I just floored it. 2006 Defender Double Cab- Zambezi Silver
Post #452825 6th Sep 2015 6:31pm
excossack
I have unplugged the clutch switch and now the gear changes are much smoother with less clunking in the drive line. 1999 Defender TD5 110
Regards
John M0VAZ
Post #452839 6th Sep 2015 7:09pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Anti stall on a td5 works without increasing the rpm like the Puma does. But as soon as you touch any pedal the ECU expect you to take controll so anti-stall won't be working then.
Just drive in first low and it will work as long as there are not to sudden changes.
Here I am showing/testing the anti stall on my 90.
http://www.youtube.com/watch?v=qQrDcALvG0Q Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #452861 6th Sep 2015 7:51pm
srod
In my '03 td5 defender - towing 1.5 ton boat up a steep slip, high-range, slowly raise the clutch, no throttle, off we go with no sign of stalling. Also works in any hill start situation.
Post #452874 6th Sep 2015 8:17pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I've used this technique on icy roads..works a treat.
Post #452951 7th Sep 2015 8:30am
Puma anti-stall doesn't increase the engine revs, it fuels the engine (rather like a governor would) to hold the revs steady. The Puma anti-stall is significantly more highly developed than the TD5s and works very well, though it is worth remembering that the moment the ECU detects a throttle pedal input the anti-stall feature is over-ridden and pedal control takes over. Consequently if you are just touching the throttle pedal you can stall it quite easily.
Post #452962 7th Sep 2015 9:26am
roel
The Puma will increase the rpm to about 1000 rpm and keeps them there. The td5 tries to do the same only at the standard stationair rpm about 800 rpm. That 200 rpm make a lot off difference in capabilities.
And yes the Puma anti stall works better. Roel
Post #453193 7th Sep 2015 10:25pm
Puma idle jack does that (increases engine speed), but it's a completely separate system to anti-stall and present for a different purpose.
If you are in low box and pull away without touching the throttle, then both AS and IJ will be active giving the impression that the AS has increased the engine speed, however if you do the same when not in low box then you won't get the IJ and the revs don't increase.
Post #453212 7th Sep 2015 11:31pm
roel
You call it 2 separate systems, Land Rover gives it 2 names, but it comes all from the software in the ECU. Twisted Evil
Here they work together and work goed, better as with the td5.
http://www.youtube.com/watch?v=0jhuKLrjJLg&feature=related
Ok IJ works only in low 1 and low reverse, AS should work in all gears.
Did you notice that LR used a LHD 90 for this show. Is that because a RHD can not do this? Or is the ignition key better positioned for this test. Whistle Roel
Post #453254 8th Sep 2015 8:14am
