Home > Puma (Tdci) > economy
Page 1 of 7 1234567>
economy
i just refilled my 110 tdci and the light cam on at 642km, and it cost 114chf's to refill, what do you get on a tank to the bing/yellow refill light?
I think this works out as ...
114chf divided by 1.70chf/litre = 67 litres
9.58 litres per 100/km....
is that good or bad ???
Post #39630 2nd Sep 2010 7:50pm
harveyg77
I do 26mpg, if I want economy I'll get a Mondeo/Insignia diesel ;/)
Post #39632 2nd Sep 2010 8:16pm
Naks
Re: economy
Pretty good, depending on the load in your truck and mileage.
With a roofrack on, my avg consumption is hovering around 10.5-11l/100km, but it only has 10000km on the clock. Once can expect things to loosen up and consumption to go down marginally in the long run.
I also add 2-stroke oil with every 2nd tank, which helps lubricate stuffs and I change the oil every 10Kkm.
Post #39633 2nd Sep 2010 8:16pm
hornet
Re: economy
[quote="bpman"]i just refilled my 110 tdci and the light cam on at 642km, and it cost 114chf's to refill, what do you get on a tank to the bing/yellow refill light?
is that good or bad ???[/quote]
Did you use a swiss calculator for that? :whistle:
I calculeted roughly 10.5 litres per 100km -- that turns out to be the average consumption for a 110.
Post #39687 3rd Sep 2010 3:37pm
Hornet... not sure what you mean.
I travelled 642km = distance
I added 67 litres (which cost 114chf) = volume
to calculate the consumption, divide the distance by the volume...
642 divided by 67 = 9.58
What's special about a Swiss calculator Shocked
Post #39693 3rd Sep 2010 4:24pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
You have it wrong, it's 67 (volume) divided by 6.42 (distance) = 10.4361370717 l/100km
Post #39695 3rd Sep 2010 4:32pm
spudfan
Ireland
Puma 110 station wagon, last check-61.19 litres (13.49 gallons), 396.5 miles =29.4 mpg. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #39704 3rd Sep 2010 5:36pm
The Boy
Thats good
I just filled mine up......65.5lts by 4.546 = 14.4 gals and did 334 mile which gives 23.19. Big Cry
Post #39706 3rd Sep 2010 6:13pm
K9F
Since April of this year I have covered just over 5000 miles in my 90 and refuelled 17 times! My severest economy was 26.73 MPG and my best 31.65 MPG. No map on for a significant time of that but back on now and of late been getting about 28 MPG on average last four fills!
Got no reason to complain me! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39707 3rd Sep 2010 6:36pm
The Boy
I think a lot of it is down to the extra weight of the 110 and the roof rack must take 2 miles off the gallon.
If I could avarage more or even the same as all my other Defenders I would be happier but I suppose it is all part of owning a land rover.
Post #39710 3rd Sep 2010 7:00pm
Markh
England 2010 Defender 110 Puma 2.4 XS CSW Java Black
I've got a 110 xs, new end of March, done nearly 10k miles. I've averaged 28.5 over that distance my best being 31 mpg. Normally don't run with roof bars etc. On holiday at mo with bars and a roof box and mpg gone down to about 26... "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..."
Post #39717 3rd Sep 2010 9:02pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
i did 739 km and i refilled my 110 with 70,6 lt x 1,21euro = 85,4 euro
9.55 litres per 100km www.newfoundland.gr
Post #39735 3rd Sep 2010 11:14pm
totoD110
Mine is 9.3 KM per liter average mostly city driving w light foot. Im running BFG km1 33" MT tires.
Post #39758 4th Sep 2010 6:01am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
Fuel consumption
I constantly travel between London and Gibraltar loaded up through Spain and end up averaging 32-34 mpg. But then my truck is a 90!!
El pepe flamenco JLS
'El Pepe Flamenco'
Post #39840 5th Sep 2010 12:01pm
K9F
Re: Fuel consumption
jlerra wrote:
averaging 32-34 mpg. But then my truck is a 90!!El pepe flamenco
Mine is a 90 too...Thought I was doing well, those are very impressive figures considering you're loaded up too! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #39853 5th Sep 2010 1:05pm
