Home > Technical > Badly worn drive shaft / flange
Page 1 of 4 1234>
Clive
Having experienced some fairly significant transmission backlash, I pulled my "new to me" 90 apart today to check on the condition of the drive flanges and was horrified to find both front shaft ends like this -
Once I cleaned it all out, I found there is a lot of wear on both the shaft and flange, the rear ones were no better.
It's easy enough to replace the rear halfshafts, they just slide out from the diff, however the front ones appear to be integral with the CV joint and in behind the hub, so how much stuff needs to come off to get them out?
Also, where's the best place to get decent replacements?
Post #417403 19th Apr 2015 9:35pm
munch90
Never seen one quite as bad as that
i took my flanges off and greased when new , always dont it never had one wear at all
Post #417406 19th Apr 2015 9:43pm
shaggydog
Shocked I don't think that has ever seen grease in its life! Thats appalling!
Bad news is you need to split the swivels to get the front half shaft out (not too difficult, take top and bottom swivel pins out then remove and hang up out the way being careful not to damage the brake lines) I have never replaced a short halfshaft though - I have a feeling they are circlipped into the Cv but unsure on where. I'm sure someone else will be able to provide more detailed guidance.
As far as parts go Ashcrofts are held in high esteem for there halfshafts - not sure how they compare to genuine Land Rover in price though. Ether would be fine for use. As far as drive flanges go I recently used Bearmach ones on my rear axle and was very happy with the fit - Nice and tight! I would recommend degreasing them and then painting them before you put them on as mine the paint seems to have fallen of in the first 2 weeks of being on there which makes them look untidy.
I did a write up of my rear ones if its any help to you? http://www.defender2.net/forum/topic28138-105.html Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #417408 19th Apr 2015 9:43pm
Clive
Yes it was pretty bad, this is one of the rear ones -
Post #417411 19th Apr 2015 9:49pm
shaggydog wrote:
Bad news is you need to split the swivels to get the front half shaft out.....
No you don't! You just need to remove the stub axle. In essence do the following,
1. Remove roadwheel
2. Unbolt caliper and hang aside, taking care not to damage the hose. If it's the first time they've come off you'll have to slot the bracket on the top swivel pin to release the pipe (obvious what needs doing when you look)
3. Remove drive flange
4. Remove hub from stub axle
5. Withdraw halfshaft and CV joint assembly.
Post #417421 19th Apr 2015 10:05pm
munch90
^^ yes agree dont touch top and bottom swivels
do as above
Post #417422 19th Apr 2015 10:07pm
shaggydog
Bow down Bow down Bow down More experienced sages have spoken. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #417426 19th Apr 2015 10:16pm
Clive
Thanks guys, not too daunting then, sounds like a job for next weekend 👍
Post #417430 19th Apr 2015 10:21pm
munch90
Might be worth getting new flanges first and try on shaft before jumping in and getting new shafts as well ( that front one might be a bit passed it Laughing )
Normally when any splined shaft wears it the outer that wears more then inner
Post #417433 19th Apr 2015 10:22pm
Clive
Both front ones are definitely well past it Shocked
The "teeth" of the splines are worn to points with steps on the sides where they locate on the flange, the original flat topped profile still shows either side, the flanges are worn even more.
For what it's worth and for peace of mind, I'm going to replace the shafts and flanges on all four corners, I've just ordered all the bits from Steve at Advanced Factors. Hopefully it will be a better drive afterwards Thumbs Up
Post #417520 20th Apr 2015 11:10am
Fatboy Slim
Wales
Must be honest I'd be welding the backs up and changing the fronts when they were totally knackered if it was mine. Get your moneys worth out of them. You'll be doing them again before you know it so get every last mile out of them......
Post #417622 20th Apr 2015 3:49pm
Clive
To be honest, I don't really fancy taking a chance on one of them letting go while I'm out and about and leaving me stranded.
Considering they've already done 130 odd thousand miles over 11 years with little or no maintenance, I don't feel too hard done by Whistle
Post #417750 20th Apr 2015 9:33pm
JWL
The thing with a Defender is that if one goes when you're out and about then you can still get home with the magic little gearknob. Put the centre difflock in and hey presto back into motion again.
It can be a little un-nerving when you've just pulled across a busy main road at a crossroads and one lets go, having the prescence of mind to put it in difflock is not allways there when you can see an artic lorry getting closer and closer Whistle
Post #417768 20th Apr 2015 9:52pm
^^^ By the time it happens for the fourth time (two diffs, and two drive flanges) it becomes instinct! Laughing
Post #417773 20th Apr 2015 10:05pm
JWL
Oh yes Whistle
Post #417798 20th Apr 2015 10:57pm
Page 1 of 4 1234>
