![]() | Home > Puma (Tdci) > Recall - Wheel Hub |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 ![]() ![]() |
Was it for your 2014 110 ?
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1866 ![]() ![]() ![]() |
Yes Grizz 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
CLCraig Member Since: 05 Aug 2014 Location: Somerset Posts: 104 ![]() ![]() ![]() |
Any ideas on which production numbers are affected?
This recall, P053 affects vehicles built between 24/10/2014 to 04/12/2014.
Vin Range: LD461900 - LD464300 Any questions ask away ![]() Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Ok thank you mine was September 14 but will check the VIN to be sure.
Phew .. Mines July
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 ![]() ![]() |
A friend had the same problem on a 300 tdi Disco front wheel locked up and a broken stid punched through the hub. Good job he was only driving slowly as he had just pulled out of the yard at work.
Uncas |
ATW Member Since: 13 Dec 2014 Location: Singapore Posts: 102 ![]() ![]() ![]() |
Hi Guys,
I am from Singapore and i just took delivery of my defender 110 hard top. It's been less than 2 weeks and my defender is in the workshop.. and i just came across this article. I have experienced the front left wheel a loud noise from the front undercarriage and my front wheel being locked and much vibrations when driving. not sure if my defender is in the list. but its made in november 2014... my vin is SALLDHNP7FA463016 Is it possible to assist me to check if i am on the "lucky list" please? |
^^Yes, yours is in the range for the recall! An engine to TDi for!
thanks for this!
delayed reply! |
Nearly five years has to be some kind of record
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 ![]() |
^^^ A bottle overboard.....
haha!! my bad!
