![]() | Home > Wheels & Tyres > Boost alloys Vs Freestyle alloys - offset |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5920 ![]() ![]() ![]() |
Do Boost alloys have a different offset to Freestyle alloys. This style > http://www.ebay.co.uk/itm/bf-goodrich-all-...4d2de87a0e 1999 Defender TD5 110
I think Freestyles have a +33 offset. See Mr Tyre's post here......
http://forum.difflock.com/viewtopic.php?t=6470 Same offset for boosts....the PCDs are different on the Freestyles. Hopefully someone in the know will be along to confirm as my research was done with Google not first hand experience. http://forum.difflock.com/viewtopic.php?t=...8e0ddda744 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 18th Feb 2015 8:04am. Edited 1 time in total |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Both the same - 33mm
Thanks all. That answers that then. 1999 Defender TD5 110
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 ![]() ![]() ![]() |
Hi All,
Sorry if this is a stupid question but how do I find the offset specifications for rims? I am really interested in values for boost, which I now from this post ![]() 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17669 ![]() ![]() ![]() |
Offsets:
HD steel wheels ("Wolf") +20.6mm Sawtooth +20mm Deep Dish +33 Freestyle +33 Standard LWB steel +33 Boost +33 Disco 1 standard steel +20 |
Thanks Blackwolf that helps a lot.
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
The wheels offset figure isnīt the whole story, as it is the distance to the centreline of the rim. The width of the rim 5.5,6.5, 7 0r 8", has also got to factored in.
I put together a table showing how much effective width (per side) the listed wheels are in comparison to a stock 5.5" steel wheel. I have ZUīs which means that the outer edge of those wheels (and tyres) stand 41,1 mm further outboard than the stock ones, or (41.1 - 19.1) 22 mm further outboard than Boosts or Freestyles. stock steel wheel 0 Freestyle Alu. 7 x 16 19,1 Boost Alu. 7 x 16 19,1 Sawtooth Alu. 7 x 16 23,5 Wolf Steel 6,5 x 16 25,1 ZU Alu. 7 x 16 41,1 Dotz Dakar Steel 7 x 16 44,1 CW Alu. 8 x 16 59,8 Hope this helps, and makes sense .-) 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
Be careful buying Freestyles for a 110. They were never offered as an option due to load rating I think on the 110
@ginjez Thats why I am buying some Boost alloys instead (plus I think they look better) - thanks for the heads up anyway 1999 Defender TD5 110
