Home > Maintenance & Modifications > Washer Jets
Grenadier
Washer Jets
Just popped into my Defender for the short drive home. It is covered in a mix of melting snow, mud and salt. The windscreen is covered. I am about to upgrade to some Silblades, but does anyone know of any upgrades to the washer jets? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #390630 20th Jan 2015 7:07pm
landy andy
Many comments on washer here. Try the search function.
http://www.defender2.net/forum/topic34027....een+washer
And I wouldn't consider siliblades as an upgrade.
Andy
Post #390642 20th Jan 2015 7:28pm
Grenadier
Thanks for the link Andy.
Why not silblade? No good or something better? Monsieur Le Grenadier
Post #390674 20th Jan 2015 8:08pm
landy andy
Found them to be not very good personally, and others have mentioned it recently, for me Bosch are better, others say areo are better, but I prefer my blades from the main dealer (well Dan at Duckworth's), as I find them to be the best and quieter.
http://www.defender2.net/forum/topic33836.html?highlight=aero
http://www.defender2.net/forum/topic33694....p;start=15
Andy
Post #390721 20th Jan 2015 9:04pm
Anderzander
I've bought aero ones from eBay and been really pleased with them.
Really good prices on there too.
Post #390725 20th Jan 2015 9:10pm
LRmud
Scotland 1989 Defender 90 300 Tdi HT Baltic Blue
Bosch AR13 Aero blades for me: first class Thumbs Up
Post #390733 20th Jan 2015 9:16pm
Philslandy
Germany 2002 Defender 110 Td5 SW Epsom Green
What works quite well concerning the washer jets is to Mount them on the wiper arms, so the water is directly where needed.
For that purpose some guys from a german Forum used the one`s from Mercedes Actros (to Clip on) or `from Renault Trafic (to glue on).
Then you would just take off the hose from the original middle washer Jet and put on each wiper arm a longer one.
Another upgrade is a heater in the water tank...
Im sorry i don`t have any Picture for you at the Moment...
i plan to do this modification to - it works much better Very Happy
Post #390858 21st Jan 2015 6:38am
Philslandy
Me again, found some pics Thumbs Up
Post #390859 21st Jan 2015 7:24am
Grenadier
Thanks Phil, the Mercedes option looks like a great fix. Better than gluing on the Traffic versions, which being Renault will probably break anyway. Stick with German tech. Will try to track them down. Cheers. Thumbs Up Monsieur Le Grenadier
Post #390932 21st Jan 2015 10:56am
Philslandy
@ Grenadier: ask the MB parts dealer for those wich they Mount either on "Actros", "Sprinter" or "Vito"
The last 2 one`s are eventully a Little smaler.
For the Actros one`s i can give you the parts numbers These guys used:
- 2 washer jets: A 000 860 37 47
- 2 connectors: A 631 869 00 24
- 2 Hose(s) : A 531 997 40 82
Thumbs Up Philip
Post #390941 21st Jan 2015 11:11am
K9F
I use Silblades and find them good but I don't cover many miles in my Landy so they have lasted me well and give me excellent service. The Bosch ones also get good reviews and we have them on our other family vehicle. If the expensive cost of the Silblades sits comfotably with you I don't think you'd be disappointed if you bought them. Nevertheless opinions vary. Ultimately you decide but with either one you'll be getting a good wipe! Rainex is also very good if the roads are dirty. If you can adjust the jets with a small pin perfectly (took me a while of trial and error) I could not personally justify the upgrading of the washers as mine seem ok coupled with a decent set of blades.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390947 21st Jan 2015 11:20am
kevinf
I fitted Vito washer jets to mine and screwed a tee piece into the original central mounted washer jet works a treat just note if you use the Vito pipe kits they come with a joining piece that's meant to clip onto the Vito wiper arm, the joining piece has a small pin hole in it to squirt a fine jet of water onto the screen as the arm sweeps across it this will have to be blocked as the joining piece is ideal for clipping the pipe to the lower windscreen gutter!
the Vito pipe is also small enough to pass thru the spring on the wiper arm making it a neater job
hope this helps kevin
Post #391005 21st Jan 2015 1:22pm
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Here’s the mod I did to my screen wash on my Puma 90 I modded my washer jet nozzle so I could fit two lengths of washer pipe to it. Then looped the pipe out of the washer nozzle along the bottom of the screen gutter and looped back up along the wiper arms to triple washer jets fixed to the wiper arms. This gives a great spray directly on to the screen where needed and combined with Bosch AR13 Aero blades and a good screen wash gives a great screen clean under bad weather conditions.
Triple washer jet EBay item eBay Item No. 351286987143.
Washer pipe DNC101720 1 mtr
After removing the washer nozzle, the two jet tubes can be seen on the inside they are almost round with just a small flat section on the front as the complete thing is a one piece moulding.
The moulding has to be cut and trimmed
Just to leave the two tubes
The washer nozzle is then refitted and new pipes attached to the tubes. When trimming the tubes check the diameter will allow the new pipe to push on tight.
Run the new pipes along the gutter and loop it back up the wiper arms. I tywraped it to the gutter and along the wiper arms, added a short length of convoluted tube where it would rub on the gutter edge when the wipers are working.
Attach the new triple nozzle jets to the tops of the wiper arms and cut pipe to length and fit to nozzle. I had to replace the self tapping screws that clamped them on with 3mm bolts and nuts. The self tappers rusted up and were hard to remove. They have to be removable to allow the wiper blade to be attached to the arm but they are in the optimal position high up the arm so I don’t mind removing them each time I replace the blades.
They have been on for about a year now and work well giving a good screen clean even under bad weather conditions. The only thing I have not experienced with them yet is in below zero conditions for a prolonged length of time. With the tube being exposed I think they could freeze up but not often in this neck of the woods. I am using screen wash fluid neatish so that should be ok for very low temps. Hope this helps.
Fletch.
Post #391277 21st Jan 2015 11:46pm
ZeDefender
Now that's very clever - might get rid of my T joint Thumbs Up Tell someone you love them today because life is short.
Post #393294 28th Jan 2015 1:36pm
x-isle
Loving the triple washer mod.
....added to the To Do List. Thumbs Up Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #393297 28th Jan 2015 1:46pm
