- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Dinnu
Ianh wrote:The Penrite oil site provides a good insight into the ACEA standards. Including C1 is Sulphated Ash <0.5% , and C3 is Sulphated Ash < 0.8%.
These percentages are small, however in comparison C3 would potentially have 60% more sulphared ash than a C1, which would not be good for a DPF.
https://penriteoil.com.au/knowledge-centre...ations/364
That indeed is very informative
The thing is that the more I read is the more seems like that the C1 protects the dpf and to certain extent the environment more than the engine. And engine failure is not cheap either.
Very confusing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
23rd Apr 2024 7:24pm |
Ianh
Dinnu wrote:The thing is that the more I read is the more seems like that the C1 protects the dpf and to certain extent the environment more than the engine. And engine failure is not cheap either.
I think you sum it up perfectly, hence my strategy to balance things up is to use C1 oil to protect the DPF but change Oil every 5K miles or less to protect engine.
23rd Apr 2024 8:22pm |
