![]() | Home > Puma (Tdci) > Another one with worn splines!! |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Hi
I am glad i could help out on this, and you have found this post helpful! To remove the large nut, i am fortunate enough to have a 3/4 air gun which will wizz off anything you put it on! Dont forget a "dab of Loctite" on the threads! I did not know the torque of the nut so i done it up to RED FACE TIGHT! ![]() Having talked to the owner of the 90 today, he says it feels like a different car, much smother through the gears and no clunk when taking up drive, he was very happy. So even though there was very little wear in the shaft, replacing and greasing really does make all the difference ![]() Wanted, Forward Control Anything considered. |
Myo Member Since: 13 May 2012 Location: Cape Town Posts: 30 ![]() ![]() ![]() |
Ian, is this an official bulletin from LR? I'm on my second intermediate shaft, 2010 90, the last one went for 9000km ![]() Anyway, I just sent the dealer the reference number from your picture, will wait and see... Myo |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Ashcroft do an upgrade for this now also 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Just had my output shaft replaced on a MY2010 90XS with only 17500 miles on the clock, exactly the same with no lubrication on the splines. Shaft failed whilst driving on the M40 near Beaconsfield, suddenly lost all drive without warning even though engine was running and it was in gear, had to be recovered to JLR dealer. Upon removal of the transfer box dealer sent me a video showing the output shaft rusty and bone dry.
Vehicle has been repaired and JLR have offered a goodwill payment of 50% towards the cost as the vehicle is out of warranty. I would have thought that something like this would warrant a recall, surely it is a safety issue? Anyway be warned if you have a 2010/2011 plate then this shaft WILL fail and is likely to leave you stranded without warning. |
Yes it was the info sheet my dealer gave me when I done the shaft on one at work ![]() Wanted, Forward Control Anything considered. |
That's the same parts list that the dealer has just given me on my invoice so it must be an official JLR bulletin.
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
Just wondered if you can tell me if you know this issue has been solved on the later MY editions please?
Cheers, Peter. ![]() |
Would be interesting to know if they have actually improved something , only 10 years late
![]() basic engineering skills really !! |
Ask for an answer on the customer relations sub forum... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17670 ![]() ![]() ![]() |
I don't think anything has changed, except that possibly they're lubricated better on assembly.
I have often wondered why vehicles built circa 2010 seem to be more susceptible to this failure than others. |
^^^ lack of quality control as usual
BykerPete Member Since: 02 Feb 2015 Location: Midlands Posts: 159 ![]() ![]() ![]() |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Most informative, thank you.
I plan to remove the transfer box next year to carry out the above work. I had a new shaft fitted, last year under warranty. I wonder if you could fit a C.V. boot (cut to suit ) Around the splined shaft coupling to help keep the grease in and the dust and water out. Has anyone tried this, I understand if you fitted this with, tie straps at 180 degree off sets the shaft would remain balanced Excuse the spelling I`am better with spanners and wires. |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
The ashcroft kit looks promising. Next time I do one I'll try and get one to trial out. Greasing will prolong the life a little but it's certainly not going to cure the problem.
