Home > Group Buys > [For Sale] Castrol Act Evo Group Buy (and another deal) |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 |
Anyone else interested? Close to getting 10 for the deal, just need a couple more.
Cheers Tim Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
22nd Oct 2014 9:42am |
Good Afternoon,
I'll have to talk to tim, who is back on Monday to see what he can do. Cheers Phil Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
29th Oct 2014 4:17pm |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
That's not strictly true, is it? ... By my reckoning, counting all the multiples that members have requested, you already do have the equivalent of over 20 people signing up for a litre, which means the group deal should be offered at the lower rate of £6.30, or are my sums all wrong?... Anyway, unless you inform us we have not breached the 20+ sign-ups, I will try one of each please... Although I would like guidance as to the use of the 2SO as a diesel additive please... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
29th Oct 2014 4:32pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
2 of each please Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
30th Oct 2014 8:09am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3616 |
EVO 2T
see below I have stopped using this in my BMW and now use the higher spec Power 1 racing due t the cat and dpf although I did not have any problem using this for the first 40k miles and 3 yrs. Note also there was a recall on this , see previous post due to water in it, caused a microlite to crash. I still however want a bottle for my chainsaw and strimmer Act>Evo 2T ________________________________________________________________________________ Applications ________________________________________________________________________________ Features / Benefits ________________________________________________________________________________ Specifications / Performance ________________________________________________________________________________ Storage ________________________________________________________________________________ Health, Safety and Environment ________________________________________________________________________________ Typical Characteristics Castrol Act>evo 2T is a modern, high quality 2-stroke engine oil for modern engines. Its Deposit Protection Formula is designed to provide continuous protection against the build up of carbon deposits on the engine and spark plug during use, keeping them clean to ensure fast and reliable starting. Castro Act>evo 2T is suitable for use in all 2-stroke motorcycle and scooter engines from both European and Japanese Manufacturers. It is designed for both oil injection and pre-mix lubrication, as per manufacturers' instructions, up to a fuel/oil ratio of 50:1. · High performance additives protect components from deposits in use · Good lubricity, protecting pistons from scuffing · Good protection against exhaust system blocking · Low ash formulation to reduce pre-ignition & catalyst deterioration · Designed for both oil injection and pre-mix systems up to 50:1 · Exceeds JASO FC and API TC All packages should be stored under cover. Where outside storage is unavoidable drums should be laid horizontally to avoid the possible ingress of water and the obliteration of drum markings. Products should not be stored above 60°C, exposed to hot sun or freezing conditions. Health, safety and environmental information is provided for this product in the Materials Safety Data Sheet. This gives details of potential hazards, precautions and First Aid measures, together with environmental effects and disposal of used products. Castrol International will not accept liability if the product is used other than in the manner or with the precautions or for the purpose/s specified. Before the product is used other than as directed, advice should be obtained from the local Castrol office. Page 1 of 13/03/2007http://fusion.bpweb.bp.com/bpglis/lubtds.nsf/FusionProductWeb/5E7170F57AD157E0802572020 ... ________________________________________________________________________________ ________________________________________________________________________________ ________________________________________________________________________________ ________________________________________________________________________________ The above figures are typical of those obtained with normal production tolerance and do not constitute a specification. ________________________________________________________________________________ Test Method Units Value SAE Test Method(s) Unit Min Typical Max Density @ 15C, Relative ASTM D4052 g/ml 0.8634 Viscosity, Kinematic 100C ASTM D445 mm²/s 6.5 6.9 8.0 Viscosity, Kinematic 40C ASTM D445 mm²/s 37.0 37.4 38.5 Flash Point, PMCC ASTM D93 °C 70 73 Pour Point ASTM D97 °C -45 -39 Colour ASTM D1500 1.5 This Data Sheet and information it contains is considered to be accurate at the date of printing. No warranty or representation, expressed or implied, is made as to the accuracy or completeness of the data and information contained in this publication. It is the User's obligation to evaluate and use products safely and within the scope advised in the data sheet and to comply with all applicable laws and regulations. No statement made in this publication shall be construed as a permission, recommendation or authorisation given or implied to practice any patented invention without a valid licence. The Seller shall not be responsible for any loss or damage resulting from any hazards or risks identified in the data sheet and which are associated with petroleum products concerned (provided that this disclaimer shall not affect any statutory rights of the Buyer of the petroleum products concerned). DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
30th Oct 2014 8:18am |
Hi Folks,
Thank you for being patient, we have created an Discount code so you can have 1 Litre of Castrol Act Evo 2t and 500ML of Millers Oils Diesel Power EcoMax for £15. To get this offer please use the Discount Code:DEFOFFER This offer will be running all week until 10th November 2014. Cheers Oilman Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
3rd Nov 2014 11:37am |
Bev Member Since: 03 Apr 2013 Location: Perthshire Posts: 266 |
Ordered 2002 Td5 | 90 County Station Wagon | Oslo Blue
2006 Td5 | 90 County Station Wagon | Tonga Green (Gone ) 2002 Td5 | 90 County Station Wagon | Zambezi Silver (Gone) |
3rd Nov 2014 11:32pm |
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 283 |
Not interested in the Millers, anything on just on the 2SO.
Mark |
4th Nov 2014 7:24am |
Hi Folks,
If you don't want any of the Millers Oils Diesel Power Eco Max then you can have 15% of Castrol Act>Evo 2T please use the discount code: DEFCASTROL Cheers Oilman Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
4th Nov 2014 10:18am |
The above code say it gives 10% not 15%?
Regards Mark. |
4th Nov 2014 3:50pm |
hI,
Please try the code again I have changed it Oilman Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
4th Nov 2014 3:55pm |
Done - thank you.
4th Nov 2014 7:04pm |
Aghhh - sorry - missed placing my order in time - I was working away Is it still available? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
27th Nov 2014 3:24pm |
Stripygitface Member Since: 16 Sep 2014 Location: Kent Posts: 78 |
I am trying to contact Oilman, but currently don't have enough Forum Posts to be able top PM, therefore would it be possible for you to contact me please.
Gordon |
9th Dec 2014 10:45am |
