Home > Puma (Tdci) > Defender rear tail lights and rear wiper erratic behaviour
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Hi lads, I have an odd problem with my 2007 110 H/T. The rear lights are all working but not as they should be Crying or Very sad the indicators stop working if you put Yor foot on the brake and stay on,and the parking lights will flash if you put the indicator on, and to top it all off the rear wiper has stopped working or when I put it on the tail lights come on?
I can't see any obvious fault in the loom as I stripped it back to the y piece at the back of the rear crossmember.
It's driving me nuts Shocked
Any ideas?
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #362705 6th Oct 2014 8:11pm
munch90
bad earth 100% I'd say
Post #362707 6th Oct 2014 8:13pm
John110
Lord that was quick! Where would it be earthed? I only ask because on the lorry it's bolted to the chassis directly behind the battery box.
Fair play and thanks for the prompt reply Thumbs Up For those who understand, no explanation is needed...
Post #362708 6th Oct 2014 8:15pm
Does indeed sound like an earthing fault.
Post #362709 6th Oct 2014 8:19pm
munch90
not 100% on this , but I know there is a earth on to the transfer gearbox opposite side to the battery up beside the drivers side sit box in the gap between chassis and transfer , I think it may be for back light etc as the loom to rear runs on that side
Post #362713 6th Oct 2014 8:23pm
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
If you mean this connector then yes, thats the earth for the rear lights etc.
[URL=][/URL]
Post #362748 6th Oct 2014 10:11pm
munch90
that's the one
thanks
Post #362754 6th Oct 2014 10:19pm
John110
Cheers, I'll get under it in the morning and check it out.
Thanks a million Thumbs Up For those who understand, no explanation is needed...
Post #362761 6th Oct 2014 10:37pm
John110
Spot on lads, everything is back working fine! The bold was a small bit loose Thumbs Up
Thanks again
Post #362968 7th Oct 2014 8:18pm
Thumbs Up
Just goes to show what odd things can happen with an earth faulty.
Post #362971 7th Oct 2014 8:30pm
munch90
that's good then , nice to have a easy fix once in a while and not the dramas that defender ownership can bring Rolling with laughter
Post #362974 7th Oct 2014 8:32pm
John110
I'm still in shock that it wa that simple! Laughing For those who understand, no explanation is needed...
Post #362978 7th Oct 2014 8:42pm
