![]() | Home > Maintenance & Modifications > hard top interior side pannels |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
I've done mine 6m MDF from B&Q 8x2 sheet...some cheap carpet from carpet right....carpet glue cut to size drill one hole for seat belt .....really easy fits under head lining
Jamie R Member Since: 24 Oct 2009 Location: Edinburgh Posts: 6 ![]() ![]() ![]() |
I fitted the La Salles side panels to mine a few years ago. They have been great, very tough. They have had a lots of stick as it is my work vehicle and no cracks. They only thing I would say is they were a bit of a pain to fit. You need to cut the panels a bit to get them to fit right and taking out the panels supports in the middle of the panels was not fun on a brand new truck. I also put rock wool behind them which has cut down on noise. I can put some pictures if someone can tell me how to do it. As all my pic's seem to be to big!
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 ![]() ![]() ![]() |
i did mine same as fekete BETTER TO REGRET THE THINGS YOU'VE DONE THAN REGRET THE THINGS YOU HAVE'NT
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
I think Mud Stuff are planning a liner for hard top sides - I think they'll have tie down points / pockets / straps for holding stuff in place. My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
how do you secure the pannels to the side to stop them rattling |
They fit behind the trim at the back and the seat belt holds them in...I also put foam behind them
Mud Stuff have so far done a replacement rear door panel They are awaiting the 90 hardtop panels to be made Then they will do the 110 Utility wagon side panels. Have our name down for some of the first of those Brendan |
i like the sound of these would be interested
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
I made my own from 9mm external ply, covered in vinyl from Dunelm Mills and insulated with roof insulation (Rock Wool). I fixed them by fitting M5 Rivnuts into the gutter, the vertical rib in the centre of the hard top and using self tappers into two of the three existing holes on the door edge, all prettied up with chrome screw cups.
Makes it a heck of a lot quieter and all the details can be viewed HERE MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
Just had a look at your site - very good. Great to see the evolution of the vehicle. ![]() + New Defender 110 First Edition |
