Home > Technical > Defender 90 (2004) TD5 - Front Hub
Page 3 of 4 <1234>
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
On the original nut it's where the machined section of the nut is hammered to contact the flat of the stub axle.
There shouldn't be play in the swivel housing. How are you detecting play?
Post #353015 21st Aug 2014 9:51pm
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Cheers Roel
Fifth , still don't know what you mean, cant see anything on the nut ?
If I grab the disk, once I had tighten up the nut there seemed to be play from the swivel housing ? I assume there shouldn't and that is f'k to ?
Big Cry Big Cry Big Cry Big Cry Big Cry
Post #353017 21st Aug 2014 9:58pm
Fifth Horseman
if the nut looked undamaged like this
when you took it off then its not surprising it was loose - the only surprise is that the wheel hadn't fallen off Shocked
The machined part should have been deformed to make contact with the machined flat on the stub axle.
The play in the swivel may be able to be adjusted - there are shims under the top pin. The workshop manual tells you how, there used to be one in the galleries.
Post #353024 21st Aug 2014 10:17pm
Tank
So which way round does it go on ? With the machine part towards the stub axle ie inwards ? My nut looks just like your picture ? has it been put on back to front ?
Post #353025 21st Aug 2014 10:22pm
Tank
Still confused sorry Sad
Post #353026 21st Aug 2014 10:27pm
JWL
Machined part outwards then when tightened up tap the thinner machined part onto the flat part of the thread on the stub so it has to push out the hammered bit before it can turn/loosen.
Post #353028 21st Aug 2014 10:36pm
Tank
Oh right where the flat bit is on the washer ?
This wasn't done on mine, no wonder it was had tight !
Should have gone to the garage !
Post #353030 21st Aug 2014 10:40pm
JWL
You've got it, it might have just had a light tap when it was done originally and the shape has been put back by the action of taking it off.
As a bit of consolation for you, I set about replacing the swivel bearings today on my NSF. This is the only wheel on my motor with the single nut/spacer set up for the wheel bearings. I have the complete service history for my motor and there is no mention of any wheel bearing changes prior to my ownership, now in its 5th year. I've replaced the OSF but that was the 2 nut and locking washer and I replaced like for like. I've had to tighten the rear wheel bearings and know they're the same. The NSF(single nut job) has never given me any reason to adjust or touch before today and when I took it apart it too was just sat there with no sign of it ever being tapped down onto the flat on the stub Rolling Eyes
Post #353038 21st Aug 2014 10:56pm
Tank
Found this on the web, think this is what it should look like ?
Post #353042 21st Aug 2014 11:07pm
JWL
That's it Thumbs Up
Post #353046 21st Aug 2014 11:33pm
Tank
Yep and mine didn't look like that !
Rolling with laughter Rolling with laughter
Duno how the wheel didn't fall off
Post #353064 22nd Aug 2014 8:07am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
That is just because the washer behind it has also a flat pieces and shouldn't be able to rotate. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #353097 22nd Aug 2014 11:43am
It's intrigues me that the WSM is very clear in stating the the stub axle should be fitted with the flat at the twelve-o'clock position, it at the top, both for the TD5 and TDCi. I have never yet come across an unmodified ex-factory vehicle which has had it fitted in this way, always just at some random position.
I don't see that it actually makes any difference except that it is possible harder to stake and unstake if not at the top.
Post #353103 22nd Aug 2014 12:15pm
Tank
So to stake it I just hit it with a bit blunt instrument to bend the machined bit flat ?
Post #353141 22nd Aug 2014 4:14pm
Tank
Damn
What have I done wrong ????????????????
I don't have enough spline on the half shaft that stick out to get the circlip and washer on ????? What are they for ? Important ?
Duncan
Post #353153 22nd Aug 2014 5:56pm
Page 3 of 4 <1234>
