![]() | Home > Puma (Tdci) > Instrument cluster replacement |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
This should do the trick.
![]() http://www.lockwoodinternational.co.uk/def...i7148.html http://defender90xs.blogspot.co.uk/ |
SiWhite Member Since: 19 Jan 2010 Location: North Hampshire Posts: 455 ![]() ![]() ![]() |
Yup, just swap the overlay. I used the Lockwood one.
You can get a white one from tunemydefender.com for similar money if that floats your boat... My blog - www.anacreinhampshire.blogspot.co.uk 110 TD5 BuildHERE - sold! 110 Tdci Build HERE - sold! Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender! |
I did the same when I imported my 110, odometer recording Kms is ok just the speedo needs to be changed
I bought a second hand speedo binnacle took the decal out and sold the binnacle to a forum member LR would charge about £150 plus vat for a binnacle then over £400 to fit and configure to 10AS |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Could be worth speaking to Pete at Bas he may be able to help you 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Spartan Member Since: 24 May 2014 Location: Internet Posts: 8 ![]() |
thanks for all the feedback and options.
I appreciate it. |
Rugbyball Member Since: 04 Nov 2014 Location: Edinburgh Posts: 81 ![]() ![]() ![]() |
Hi all
This is an old post, but has anyone changed the dial card on the instrument cluster? How do you get the instrument cluster removed and how do you replace with a new face card (2015 2.2 puma) I read somewhere you have to turn the needles in different directions to remove them before you can replace the face card. Sounds all a bit complicated to me, not to mention risky in breaking the instrument cluster itself!! Appreciate any advise from someone who has had a (successful) attempt to do this! 2015 Overfinch Defender XS 90 1998 50th Anniversary V8 1989 90 CSW Many Discoveries... |
The needles pull off
Td5-alive also sell nice looking replacement decals |
