![]() | Home > Maintenance & Modifications > Puma Gearstick rattle / vibration cure guide (with photos) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20726 ![]() ![]() |
After reading the advice on here about how to cure the Gearstick rattle (in particular 5th. & 6th) I decided to make a little photo guide for others benefit from that have had the same issue.
I've had the Gearstick vibration noise for a long time and never got around to curing it until yesterday. ![]() 1) start removing the gaiter off of the stick by pushing it down: ![]() Click image to enlarge 2) And further until it's off of the stick, note the clips you can see each side that lock over the white part: ![]() Click image to enlarge 3) Gently pull these clips back each side both at the same time and the stick should pop out: ![]() Click image to enlarge 4) Lift Gearstick up and remove: ![]() Click image to enlarge 5) Now you can see the weights (metal) that rattle when in higher gears. ![]() Click image to enlarge 6) Now superglue the weights to the body of the stick like so: ![]() Click image to enlarge ![]() Click image to enlarge 7) Note you can see the glue along each edge of each weight, repeat this in all areas: ![]() Click image to enlarge 8 ) In my case I left the stick with the glue on for an hour as per its instructions to fully cure: ![]() Click image to enlarge Once the hour had passed I refitted then left overnight but it would be cured anyway all the same. Refitting of the stick is just the reverse of above but the gaiter is a bit tricky to get back on and over the stick but not too bad. I did this mod yesterday and tested it today and rattle is gone in 5th and 6th. ![]() The glue I used isn't specifically required for this job but if you don't already have any I used this: http://www.ebay.co.uk/itm/SUPERGLUE-SUPER-...5645643c37 Cheap, but it's extremely strong. ![]() Apologies in advance for the photo quality, it was a full day and used phone. ![]() Steve WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
perfect! cheers steve Cheers, David
Land Rovers of all shapes S3 onwards⦠Daily is a 110 V8. |
It would seem on your gear stick connection there was no grease. On mine it was covered in silicon grease, maybe the dealer as it was an ex-demo and I only got the buzz after a couple of hours continuous running, , so glue would not have worked. I used some small plastic cable ties to secure the weights. Same effect , gear stick buzz gone and it has been 3 years now.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
There was some grease there, the photos just don't show it properly. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Nice guide Steve, as usual!
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
Should be stickied
Looks like Martin has done.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134 ![]() ![]() ![]() |
Nice one, that's exactly how I did it (but you explained it much better AND photos
![]() 1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS |
Indeed, it may have been you that mentioned how to do it and what to do. Have to give credit where credit is due to those who have mentioned it before.
I just locked the fact that it's a common issue and people myself included often wanted to know what to do. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
This is what I like about this forum .. Great advice .. 5 min job making a much nicer drive
At least it means if you carry passengers they don't think your driving a bone shaker.
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Well done and thank you
![]() Puma Defender 90 |
