Home > Td5 > HELP needed headlight failure
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Hi all, my headlights didn't work when coming home this evening, I don't have dip or main beam on both sides, I do have the spots still working on main beam, am I right in thinking, the light switch has packed in. All help & guidance appreciated, can't check till the morning when it's light.
Regards Mark
Post #283503 19th Nov 2013 6:41pm
VeeTee
Netherlands
Yes, probably the switch melting because of too much amps going thru. Happens frequently, see my post earlier here. Cheers, Vincent
MySite
Post #283508 19th Nov 2013 6:51pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi Mark, Yes you are correct! Its a common Defender fault as the headlights are wired directly to the switch without the use of a relay so the switch eventually burning out is the end result. Once you replace the switch it might be worth modifying the headlight wiring to incorporate a relay to take the load off the switch to prevent it happening again in the future. Hope this helps!
Post #283510 19th Nov 2013 6:54pm
tazmarkuk
Thanks guys all help appreciated, good excuse to tell work I've gotta go home before it gets dark.
Post #283512 19th Nov 2013 7:14pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Is this all defenders? Mine is a 2004 TD5
Post #283513 19th Nov 2013 7:16pm
there was a link on the forum to a company who make a plug and play loom complete with relays for defenders ... WTF they don't fit them at standard I don't know but they are available for peeps who want a quick "proper" fix
Post #283514 19th Nov 2013 7:17pm
VeeTee
Netherlands
Link for the relay loom here. Cheers, Vincent
MySite
Post #283516 19th Nov 2013 7:30pm
cheers VeeTee Thumbs Up
Post #283517 19th Nov 2013 7:31pm
VeeTee
Netherlands
One of the first things that happened in my Defender ownership, the melting light switch - so one of my first mods, installing the relay loom along with a new switch.
Thumbs Up Cheers, Vincent
MySite
Post #283519 19th Nov 2013 7:36pm
tazmarkuk
Just been looking at new switches on fleabay, there are cheap switches at around a tenner and OEM at £25, does anyone know if there is actually any difference in quality between them.
Mark
Post #283520 19th Nov 2013 7:40pm
kipperthedog
Lucas is the one you need. Got mine from a seller called Adventure 4x4 on ebay. This was the best price I could find. About £22. I have seen reports of the ones in blue boxes lasting weeks before melting!
Will do the relay mod in the spring I think!
Post #283691 20th Nov 2013 11:59am
