Home > Technical > Rear Lower Shock Bushes
x-isle
I'm looking for some of the above as I noticed today that one of my bushes is a bit worn.
I've found part number RNF100090L, but everywhere I look, it says they are for up to 2007.
I've got a puma 110 and can't seem to find any. Anyone know if these do actually fit a Puma?
Thanks Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #247782 30th Jun 2013 3:06pm
SGH
RNF100090L is correct part number for lower rear shock bushes for your 110
Post #247783 30th Jun 2013 3:13pm
K9F
Have you considered polybushes? A thread less than 24 hours old....... Thumbs Up
http://www.defender2.net/forum/topic21477.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #247789 30th Jun 2013 4:12pm
x-isle
I did consider a Poly conversion, but I do a lot of road driving so was thinking about the increased stiffness. Craig Rogers
2007 Puma 110 XS
Post #248015 1st Jul 2013 2:07pm
K9F
Polybush do different variants for different conditions. I got an advisory on my MOT for mine and it is something I myself need to look at. I have heard the longevity of polybushes is worth the spend.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #248017 1st Jul 2013 2:11pm
x-isle
Thumbs Up Yeah, was just looking at the Dynamic Full kit - http://www.lrparts.net/defender-from-2002-...e-kit.html
Looks pretty decent. I think I'll have a failure next month on mine as one of the lower bushes is a bit loose.
In fact, decent question?
What are peoples previous choices? Performance, Comfort or Dynamic? Craig Rogers
2007 Puma 110 XS
Post #248018 1st Jul 2013 2:13pm
K9F
I suppose it depends on interpretation of the words performance, dynamic etc. Ultimately mine are 'worn' and need replacing and I shall probably go for performance as I like that word. Mine is road use only and I suppose it doesn't really matter so much?
Laughing Thumbs Up
I too was considering a full kit but bu993r it I'll replace just the shock bushes for the time being as I have worked quite a lot on the truck recently and don't need to bog myself down with anymore tinkering that doesn't need doing! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #248022 1st Jul 2013 2:23pm
x-isle
Glad I'm not the only one thinking that.
I'm going to just do the rear shocks to start with. Craig Rogers
2007 Puma 110 XS
Post #248023 1st Jul 2013 2:24pm
K9F
My need isn't as great as your but if you go ahead let me know please where you get them from, how the fit goes and of course what type? Be very interested to hear......
Thanks..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #248024 1st Jul 2013 2:29pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
Hi x-isle
My 110 failed its MOT on 1 worn rear bush, ironically they were actually easily available £2.50 + vat each from my Land Rover dealer parts department
Unfortunatly they were closed so had to buy a whole shock absorber from an autspares just to get two incorrect bushes for £36 so I could get it through the retest Sunday Morning.
Then I bought four of them from the dealer to redo both shocks, hmm still need to fit them Confused He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #248087 1st Jul 2013 5:19pm
Innuendomaster
Must be a common failing, mine are shot and in need ASAP, I was aware when I purchased too but thought they'd last a little more
Post #248088 1st Jul 2013 5:21pm
x-isle
Must be a common thing then........
Still undecided to just get standard for pennies or upgraded for a fair bit more.
I away for most of this week so I'll worry about it when I'm back! Cool Craig Rogers
2007 Puma 110 XS
Post #248089 1st Jul 2013 5:24pm
Innuendomaster
Mine is also an advisory from March, so I better get them looked at pronto. I'm going to Polybush all mine as I go along, I'm not going to rush but replace methodically as I need to.
Any advice on type as there is three types, Performance/Dynamic/Comfort. My DC doesn't carry weight, but does haul the Sankey but really need advice on which would suit me. Don't want to bounce any more than I am already Laughing
Post #248092 1st Jul 2013 5:34pm
x-isle
Well I've decided to go for the Dynamic Polybush set for the rear shocks.
I've emailed Polybush so hope to get an answer soon, but does anyone know if "Kit 12" does both shocks or do I need two of them? At £29.50 I'd expect it to be both shocks.
http://www.polybush.co.uk/shop/view/7_2002...der_(2002) Craig Rogers
2007 Puma 110 XS
Post #250457 10th Jul 2013 11:59am
x-isle
"Kit 12" does indeed contain the bushes for both rear shocks.
After deciding against them and going just for Genuine lower bushes, I decided that if I'm doing the lowers I may as well do the uppers. So I changed my mind back and have purchased the Dynamic version of Kit 12.
Hopefully, I'll get around to fitting them this weekend.
I'll let you know how I get on.
Oh and if anyone wants a set of these...... > http://www.lrspareparts.com/eshop/bush-oe-quality.html < I purchased a set of 4 that cost £6.46 including delivery. Happy for £5 inc delivery. Craig Rogers
2007 Puma 110 XS
Post #251648 16th Jul 2013 10:23am
